probably can bur touch screens are worth almost as much as a new unit
if you get a new unit , prevent scratches by using the plastic protection that you can get for ipads and phones and cut to size
posted in wrong section but if you read the warnings on the device and cutting wheel its says proper protection requirements safety glasses /face shield
Most often when a TV will not turn on it is the SMPSU that's the problem, either the protection circuitry has been invoked or there is a fault within the actual power supply.
The very best thing to do is to contact the manufacturer and ask for a referral to an authorised service center, then ask then when face to face ONLY for a "Quote" first and go from there once appraised of costings etc.
To
remove
the write protect lock, take the memory card out
of the camera, face the card towards you,
look for a small tab on
the left hand side of the card, to unlock it push the tab up to unlock
it, it will
be at the side of the card like this .
Check all of your speakers and speaker wires for shorts and grounds. If all check out fine, try reseting the radio. If there is a reset switch, it will be a small pencil tip sized depression on the face or a small hole with a switch behind it on the subpanel behind the face. If there is no reset switch, disconnect the battery for a couple of minutes.
