My heat pump always go to pre def mode, im a first time user for heatpump. is that normal for heat pump and someone told me that its better to leave the unit on for days that to turn it on and off, for efficient and economical in terms of electricity/power cost. thanks
    Novelist:
  • 135 Answers
Heat Pumps, remove heat from the outdoors and transfer it, to the inside of the home, depending on the outdoor temp, this is a slow process, so the system is usually setup to use a back-up heat system. Sometimes it is a gas furnace, but usually it is electric heaters, anytime the system goes into defrost mode - which is basicly air conditioning. The control boards will shut off the fan on the unit outside, since it is trying to melt the frost of off the coil, we do not want anymore wind chill factors than we have to, now since we are basicly in the A/C mode, the air coming into the ductwork is cold, a backup heat source is turned on, to temper or warm the air a little bit, for comfort factors and so we do not lower the house temp. During this time it is not unusual to see stream, and water dripping of off the unit outside. All of this is normal and is all done by the system, without any input from the homeowner. The amount of steam and water dripping from the outdoor unit is related to the humidity levels outdoors.
Now,,, Most systems are set up to turn on the back up heat-"the electric elements usually", when there is a 2 degree drop in room temp, so either the heat pump can not keep the home warm by itself and needs help, or if you turn the heat up over 2 degrees, it says, either the heat pump can not keep up by itself or that the owner turned up the heat,,, the result is the same, the system will give you everything that it has, heat pump and backup heat.
So it is best to set the temp on the thermostat where you want it and then just leave it,, the only reason to turn it down is for your comfort, can't sleep in a warm house, ect,, but you do this for your comfort only and not for saving money. All heat pumps have a COP rating, basicly telling you, how much cheaper the heat pump costs to run via straight electric heat. Example: With a COP of 3, for every $ 1.00 of electricity that you spend the heat pump will give you $ 3.00 worth of heat.
One other thing to consider when heating or cooling a building, is the heat loss or heat gain of the structure. Heat is attracted to cold and the greater the temp difference is, the faster the heat transfer.
What does this mean to you? If it is 40 degrees outdoors and you set the heat to 70 degrees in the home, the higher that you turn up the heat, the faster the heat transfer is to the outdoors, meaning that you lose heat faster. An expample is; like in a hospital, they give you an I.V. drip, they put the needle in your arm and hang the bag on a stand, and let it drip into your arm, the higher the bag is, the faster it drips.
Now I'm rambling; this is a very involved subject:
Basic rules: Find a setting that you can live with and leave it.
If this has been helpful, please rate me and contact me back if I can help you with anymore questions.
Sincerely,
Paul Gibson
Posted on May 05, 2010
Has anyone heard that t-stat on 4045 is supposed to installed reverse of norm?
User Manual - Braeburn Systems
www.braeburnonline.com/sites/braeburn/files/.../1010_manual.pdf
cooling system control board to test the thermostat installation. This could ...configures the thermostat for normal (NORM NON-HP) heating and cooling systems.
Heat Pump Thermostat - HeatPump-Reviews.com
www.heatpump-reviews.com/heat-pump-thermostat.html
Search Results
    [PDF]User Manual - Braeburn Systems
    This thermostat should only be used as described in this manual. ... configures thethermostat for normal (NORM NON-HP) heating and cooling systems.
Jan 17, 2016 | Toys
Goodman minisplit flashes on pre. Def. Wont start
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.
Air Conditioning Repair Tamarac
Apr 07, 2015 | Goodman Heating & Cooling
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
I have arcoaire thermostat (not digital) with Comfort Air FBA series system, vintage 1998. The bottom of thermostat has selections: ''EM Heat'' ''Heat'' ''Air'' ''Off''. I am not original owner. Q. Should...
yes go into electric heat for awhile. sometimes a heatpump will run constantlly when temps outside are not high enough./em heat mode untill temps rise or unit recovers.your unit should of gone into hot-gas defrost this maybe what your hearing. but remember electric heat is expensive to operate go back to your heatpump mode after system has a chance to recover.
Jan 31, 2010 | Heating & Cooling
Weather King 10PJB18A01 heat pump. Compressor is working, however reversing valve is stuck in cooling mode. Need HEAT! Can this be fixed without replacing entire compressor?
yes it can be fixed with a reversing valve replacement or you can check if the solnoid on the reversing valve when in heat mode is energized if not then replace
Jan 06, 2010 | Weather King 10PJA4301AH Air Conditioner
Thermostat show AUX HEAT
A heatpump has two sources of heat. One is when the heatpump is operating in normal heat mode, and the other is typically electric heat strips.
The strips come on when the unit is going into defrost, when the unit is not able to keep up with the demand for heat (really cold temps) and when the unit is not working properly.
Whne the strips are on, the T-stat displays "aux-heat" to indicate the strips are in operation.
If the strips are working properly you should have warmer air than with the HP alone. Try switchin it from "heat" to "emergency heat" and see what it will do.
When the HP is not able to keep up with the demand for heat then the heat strips come on, but they typically come on only when the room temp has gotten well below the thermostat setting.
In that situation it would be normal to see indoor temps at 63 degrees when the T-stat is set on 70.
But when you set it to E-heat it bypasses the heatpump operation and goes directly to the heat strips. If they are working properly it should maintain an accurate temp in the home.
Jan 23, 2009 | GE Zoneline AZ55H09D Air Conditioner
I have Goodman combination heating and cooling outdoor unit PBB series. I am wanting to know if when the heat is on should the fan outside turn or is that only ac
If it's a heatpump, then yes the outdoor fan will turn unless the unit is going in defrost mode. But for the majority of the time a heat pump is operating in heat mode, the outdoor fan is running.
Jan 16, 2009 | Heating & Cooling
Our toshiba ras13 skv a heat pump keeps going to pre def mode and not heating the house
this happens when the outside temp is low, asthe outdoor unit blows cold when in heating (reverse) then the unit goes to pre def to avoid it freezing. You should hear a whoosh this is the heat being blasted to the outdoor unit to defrost it, then the heat has to build up again before the indoor unit fan runs up again and blows heat. Mine does the same every 20 mins or so (its -2 outside) brrrr
Leigh
Jun 18, 2008 | Heating & Cooling
Heating & Cooling Logo
1,299 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
