Question about Sony Televison & Video
Gigaware pc to tv converter worked fine but had to restore vista and now it doesn't work. If I hit 'reset' button on gigaware the tv screen will flash the same picture as on the monitor for only a second then nothing. tv is Sony, old non-digital tube type. Please help
SOURCE: tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Posted on Sep 27, 2006
Riziel
  • 116 Answers
SOURCE: Power button flashing green on and off. No Picture
What type of monitor do you have? I need to no if the power supply or cord plugs directly into the LCD Monitor? These questions are important! Please answer these questions, I will be able to give you an answer!
Posted on Nov 26, 2007
SOURCE: help me
disconnect web cam from usb port then re-install software. be patient disk runs very slow. after software is sucsessfully installed re-connect camera into another usb port. if green light stays on, try all usb's until driver software reconizes the camera device
Posted on Jan 02, 2008
SOURCE: Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Posted on Jan 28, 2008
ziraffa
  • 827 Answers
SOURCE: gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Posted on Dec 27, 2008
Why does Gigaware 25-1141 VHS to DVD converter driver corrupt my CD-ROM?
Not compatible? Rolling back the date will remve any installed programmes after the roll back date.
Apr 20, 2013 | ASUS Computers & Internet
Lost the instructions to use Gigaware Pc Tv. Help to locate instructions how to use Gigaware Pc Tv
Hello, please follow this link to view the manual in pdf format:
Gigaware PC to TV Converter
Please remember hook it up before you turn on your computer.
You may also need to adjust your resolution down a little. Right-click on your desktop and click screen resolution to adjust the resolution
I hope you find this useful
Jul 07, 2011 | Computers & Internet
I lost my cd but i got my gigaware webcam with mic
25 -157
http://www.radioshack.com/product/index.jsp?parentPage=search&summary=summary&cp=&productId=2473604&accessories=accessories&kw=gigaware+webcam&techSpecs=techSpecs&currentTab=summary&custRatings=custRatings&sr=1&features=features&origkw=gigaware+webcam&support=support&tab=support
25-234 ( Pre Vista )
http://www.radioshack.com/search/softwareResults.jsp?sr=1&kw=25-234&origkw=25-234&kwCatId=&hideBackToAll=true
25-334 (Vista)
Oct 05, 2009 | Radio Shack VGA PC Camera Webcam
Instalacion de camara gigaware
Hola,
Descargue el primer, si es para el Windows XP, descargue el segundo uno, si es para el Windows Vista.
Y hay instrucciones para el webcam, pero ellos son para inglés :(
Gigaware VGA PC Camera (Original Drivers for Windows 98SE/ME/2000/XP (11.9 MB))
Gigaware VGA PC Camera (Vista Standard WHQL Driver (14.7 MB))
Gigaware VGA PC Camera (User's Guide)
¡Buena suerte!
Chris (ziraffa)
Dec 28, 2008 | Radio Shack VGA PC Camera Webcam
Please tell me how to install Gigaware PC Cam on my Vista Computer?
check the manufacturer site for Gigaware PC Cam and download the vista driver
Jul 07, 2008 | Computers & Internet
Gigaware USB to Serial Cable software
No need for disc, don't worry.
Radio Shack/Gigaware 26-949 USB to Serial Cable drivers (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
May 07, 2008 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
I lost my gigaware webcam software
Driver update related problems can be solved easily by: Driver Update Software for XP Vista 7 8 Enjoy
Feb 24, 2008 | Radio Shack VGA PC Camera Webcam
Televison & Video Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
