Question about Canon ImageClass D880 Copier
Paper jam internal, can't access. accordian at exit tray
  • bfugina May 05, 2010
    How do I get to the fuser unit?
I have this exact same problem. Do you need a new fuser, or is taking it out and trying to pull out the paper somehow an option? I tried with the fuser in the printer, but there's barely any paper to pull on.
Posted on Jun 07, 2010
  • 26 Answers
More the likely it is in the fuser unit of the copier .
Posted on May 05, 2010
Stuck paper tray
If the tray is stuck it may be caused by some obstruction at the rear, possibly the pickup roller.
Remove the small rear cover that gives you access to paper jams and check that there is not something jammed in there or if the paper pickup roller is stopping the tray from exiting.
Jun 02, 2011 | Brother MFC 420CN All-In-One InkJet...
How do you remove a paper jam at the site where the paper exits the printer (causing an accordian-style fold)
Turn off and unplug the machine you can open the front door open the exit side where the paper exits out gently remove paper the issue is caused by the upper fuser claws on the fuser unit they are worn you will need to replace them or replace the fuser unit assembly as other internal parts in the fuser may also be worn like the rollers
This should be done by a trained certified engineer
WHEN YOU TURN OF MACHINE MAKE SURE TO OPEN DOORS AND WAIT A FEW HOURS SO THE FUSER AREA CAN COOL DOWN CAUTION THE FUSER AREA IS VERY HOT
Feb 10, 2011 | Canon imageCLASS D320 Digital Copier
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
Printer Jam every single page.
You need to clean the exit rollers. You hold a damp rag on the rubber rollers at the top exit and then open and close the front door, it will run for a few seconds each time allowing you to clean one roller at a time. Either plain water on the rag or alcohol will do a great job and get you printing again.
Jan 13, 2010 | Brother MFC 7420 All-In-One Laser Printer
Jamming
Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
Jul 20, 2009 | Ricoh Aficio MP1600SPF Copier
How to fix paper jam Epson CX3650?
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
CREDITS: nanicool
IF YOU DONT GET FIXED WITH THIS THEN PLEASE REPLY BACK.
I SHALL BE GLAD TO HELP YOU WITH YOUR PROBLEMS.
THANK YOU
REGARDS
SWEET RASCAL
Jun 28, 2008 | Epson AcuLaser C3000 Printer
Konica Minolta Di251
Could be that it is printing a legal print on letter paper. This causes a timing error which appears as a jam. If it is accordion folding behind the exit rollers the paper could be hanging on the exit sensor flag. If it accordian folds in the fuser then the fuser needs replacing.
Jan 04, 2008 | Konica Minolta DiALTA Di200 Copier
Paper Jams
Take out the paper tray- and examine- the paper pickup on the jamming side. Do the same internally looking at the paper feed track. If you can get a vacuum nozzle and have a good suck out. It is all most certainly paper debris in the feed . Also take a look at www.fixyourownprinter .com
May 17, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Canon ImageClass D880 Copier Logo
170 people viewed this question
old marine
old marine
