Question about Kitchen Ranges
Husband tipped over range model # WFE361LVQ, gonna purchase exterior glass, but how do we install?
  • Kitchen Ranges Master
  • 43,501 Answers
Here is a tip that I wrote about that...
Range/Stove/ Oven Door Glass Replacement
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Posted on May 14, 2010
One of the burners is not working
glass or coil ,,if coil either a switch or element u can check ur element for continuitiy with a meter just pull it out and put the leads one on each side with the meter on 2000 upside down U thing... if reads sometin okay , if nothing occurs replace usually 30-50 dollars use like a mp21ya or use ur model to locate original if not then replace or switch, behind ur knob.. if glass same type of thing but ur gonna have to get access under neath u might wanna call for service. the element i gonna be more if its a glass top hope this helped let me know k thanks bye bye take care
Jan 13, 2010 | Whirlpool GR460 Electric Kitchen Range
2002 Mountaineer. How do you change the light bulb at the bottom of the driver side rear view mirror. Dan
SECTION 501-09: Rear View Mirrors 2002 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Exterior Mirror Glass Removal
NOTE: Exterior mirror glass is serviceable only on vehicles built after July of 2001.
NOTE: Passenger side exterior mirror shown, driver side exterior mirror similar.
All mirrors
  1. Position the glass in the full up position.
  1. Locate the notch at the bottom of the exterior mirror glass.
  1. Release the exterior mirror glass.
    1. Insert a long flat-bladed screwdriver in the notch.
    1. Push the screwdriver into the notch until the glass is released.
Heated mirrors
  1. Position aside the exterior mirror glass.
  1. Disconnect the electrical connectors.
All mirrors
  1. Remove the exterior mirror glass (17K707) passenger side or (17T675) driver side.
Installation
Heated mirrors
  1. Connect the electrical connectors.
All mirrors
  1. Position the exterior mirror glass on the exterior mirror motor.
  1. Place a hand against the back of the exterior mirror housing and a hand flat against the exterior mirror glass. Press the glass in place until fully seated.
Dec 26, 2009 | 2002 Mercury Mountaineer
Passenger side mirroe is broken from the neck...
is it just the glass that broke?
  1. Position the inner edge or the exterior rear view mirror glass to its maximum travel.
  1. s1h~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Place a shop towel between the exterior rear view mirror glass and the hand to avoid personal injury in the instance of glass breakage.
    Grasp the outboard edge of the exterior rear view mirror glass and pull outward.
  1. Remove the exterior rear view mirror glass.
    • If equipped, disconnect the heated rear view mirror glass electrical connectors.
Installation
  1. If equipped, connect the heated rear view mirror glass electrical connectors.
  1. NOTE: An audible click will be heard during installation.
    Press firmly in the center of the exterior rear view mirror glass until it snaps onto the exterior rear view mirror motor.
Jul 01, 2009 | 2001 Ford Taurus
Mirror glass replacement on drivers side
i don't have aviator. here's explorer, should be the same.
You will see a small rectangle where the screwdriver goes in. You are pryingtowards glass. The retention is about a 3 inch rectangle that has a lip around it that snaps onto a rectangle on the mirror body.
All mirrors
    1. Push the screwdriver into the notch until the glass is released. (and pull screwdriver towards glass)
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
Apr 18, 2009 | 2003 Lincoln Aviator
99 explorer drivers side mirror vibrates
are you trting to tighten the mirror glass or the mirror where it attaches to the body? I don't think glass is removable in 99. Only can try to press on glass to seat if unseated. not too hard.
  1. Remove the front door trim panel; refer to Section 501-05 .
  2. go to car-part.com for a used mirror. Page with * is cheapest seller.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
SECTION 501-09: Rear View Mirrors 2001 Explorer/Mountaineer Workshop Manual
REMOVAL AND INSTALLATION Exterior Mirror Glass, 2001 model Removal
All mirrors
Heated mirrors
All mirrors
Installation
Heated mirrors
All mirrors
Apr 12, 2009 | 1999 Ford Explorer
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
How to replace the ceramic range top
you need to replace the glass top itself???that might be an expensive proposition.but heres the how to. theres 2 or3 screws along the front underside of main top. this will release the top enabling you to tip back and look underneath.not a hard job, just gonna take some patients. assuming you have the new top. its gonna be a matter of taking from one and installing on other. you will not have to undo any of the wires leading to the burner elements. instead undo the screws that are holding the elements up to the top . should be 2 brackets running lent gh of unit . undo the brackets and lay the elements down on the insulation . after removing both swap out glass and reinstall new . there will be multiple ***** holes on new glass for supporting brackets. look closely at old one for proper placement
Mar 12, 2008 | Frigidaire FEF364DQ Electric Kitchen Range
Jenn Air range model SVE47600 Beeping
f7 is the code for a shorted keypad or membrane have your husband disconnect the mylar ribbion from the range and gently clean the end with a pencil eraser then reconnect and try again if that doesnt work replace the touch pad
Mar 11, 2008 | Kitchen Ranges
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
