Question about General Electric Microwave Oven
Crack in floor of microwave
Can I still use it?
  • pmagee1 May 05, 2010
    The crack is all the way through the floor of the microwave from the front left corner to the rear right corner. If you push on the floor at all it moves down.
    The microwave is a GE Profile.
  • GE Master
  • 9,098 Answers
It depends on how bad the crack is.
Generally, it will have to be sanded and repainted with high temperature paint, but it depends on the depth, etc.
Please post a new help request here to FixYa and upload a photo or two, and include your brand name and full model number so we can help you.
Posted on May 04, 2010
Why is the inside painting cracking & rust is oosing out?
Hello Miriam;
My name is peter. I am a retired field service appliance technician.
The reason your micro wave liner is cracking is the way you place the food in the microwave.
The rust is coming from the steel frame where the liner is cracked.
Go into the following video on how to repair the cracked liner. You can do this.
How to Repair Microwave Arc and Burn Marks Touch Up Paint
Apr 04, 2016 | Magic Chef Microwave Ovens
Ge spacemaker xl1800
A small crack is probably ok if you had a lot of leakage you will feel a tingle sensation in your hand if you are really worried take a small piece of foil and cover the crack that will prevent any radition from leaking, I used to repair microwave ovens and I know with the current models it is not possable for much to escape, unless there is a large hole I once serviced a commerial microwave that was used with most of the front glass missing, the user reported some tingling in his hand.
Nov 12, 2013 | Microwave Ovens
MICROWAVE METAL PLATE CRACKED
it is megnatron plate which broke. You can replace that plate yourself . Also can can work without if safely.
Jun 20, 2013 | Hamilton Beach 1.1-cu ft Microwave Oven,...
Panasonic steam convection microwave ceramic floor cracked and a hole melted into the ceramic field.
This was probably a manufacture defect right from the begining which would explain what happened. My guess there was a very small crack and quickly developed into serious problem.
May 18, 2012 | Panasonic NNCS596S Microwave Oven
My friend was going to wax her legs and was warming the wax up in the microwave when it bubbled over and made the wax bowl stick. Pulling to get it out she spilt it everywhere , in microwave , on my...
since it is a sticky wax and not paraffin or candle wax do not reheat it to remove it. Get an ice pack or stick some ice cubes in a ziplock bag and rub on the wax until it freezes/gets cold enough to crack. It should come off of all of those surfaces pretty easily once it has been cooled enough not to be sticky.
Aug 21, 2011 | Microwave Ovens
How to change microwave bulb
PLEASE UNPLUG YOUR MICROWAVE!
Remove the two screws that holds grill. They are located at the edge of the unit. Once the screws are out, rotate the grill forward from the top. It will pop right out.
Once the screws are out, rotate the grill forward from the top. The grill should pop right out.
Locate a small access cavity on the left.
Remove the screw that is located near the front of the microwave door.
Lift up the sheet metal floor to access the bulb. The bulb is located under the sheet metal "floor" on the left.
Place a flash light on the microwave floor and shine the light in the light area. This will help you see better when you replace your bulb.
Look for a small shiny reflector that hides the bulb. Use your two fingers to squeeze it a bit. Making sure not to bend it.
The bulb connection should come right out.
After you replaced the bulb, re secure the reflector and the sheet metal floor with the single screw. Test the bulb by plugging in your microwave.
Once you see that the bulb works. Unplug your microwave again and re attach the front grill. You are now done.
Hope this help in solving the problem, take care.....
Sep 16, 2010 | Microwave Ovens
My microwave magnets keep cracking
Have you checked out your waveguide and stirrer? Also ensure you have good connections & earths.
Feb 04, 2010 | Kenmore 62622 Microwave Oven
Our microwave fell to the floor and landed on its' corner. Miraculously it still operates but the metal cover is a little bent so it bows slightly on each side of the corner. If we can see light through...
Yes! hazardous to health,microwaves has a shorter wavelengths, it reflects or radiates.The gun or the magnetron is called MASER, sounds like LASER,Laser emits light energy while Maser -microwave energy.
Aug 29, 2009 | Microwave Ovens
Front Plastic door is cracked and needs replacement.
Do not use a microwave with a cracked door as it could be emitting dangerous microwaves.
Sadly the cost of replacing the door would be more that the cost of a new microwave. Look for a good sale and treat yourself.
Jun 11, 2009 | Microwave Ovens
General Electric Microwave Oven Logo
70 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
