I have a phillips md#ms3652s467. it had convergence problems and horizontal line problems. i fixed that problem by replacing a 2 ohm resistor with 2-1ohm resistors in series in my horizontal section. i now have a problem with the tv showing white horizontal lines. the relay clicks the tv comes on and then it shows the lines and stays on for 10 seconds then cuts off. the relay clicks again and the tv comes back on but shuts off after 2 seconds. just before it cuts off it blinks a few times though.
  • 3 more comments
  • vernon johnson
    vernon johnson May 05, 2010
    the standby liught is not blinking it is the screen . p[lease do not give me a weak answer to try to gain points. i need help!
  • vernon johnson
    thank you silver dragon. i am a training electronics tech, so i must learn your information may prove to be useful so i am going to try it and write you back. have a good day.
  • vernon johnson
    vernon johnson May 12, 2010
    i now see that the sync ic has 55 volts on pin 9. i also see that the tv goes completely off and the standby light goes out also. it then comes back on by itself but the standby light does not come back on and then it cuts back on. it also will cut off and the standby light will remain on for a while.
  • vernon johnson
    vernon johnson May 19, 2010
    please reply asap
  • vernon johnson
    vernon johnson May 23, 2010
    as usual you always come through. even when it takes a while you still stick in there and help with detailed information. you show concern about the individual problem and not just the "take a number and sit" attitude. you are professional and a credit to this website. thank you very much for your help.
  • 5,807 Answers
Hi
vljenterp81,
Are you referring to the 2 ohm resistor that is in series to the B+ of
the Flyback ?
If the lines is not slanting, then it is most probably a fault on
the Vertical Circuits, Start by replacing the 100uF capacitor
or 47 uF on some that is very near the Vert Out.IC, resolder
also the pins.
But if it is slanting then probably it is a misadjusted G2 voltage
or Screen Voltage. Have it lowered.
Check the B+ voltage it should not be more than +135V
If the B+ is about 77V before it turns off then most probably it is
partially shorted.
Have a check also on the capacitor on the B+ line going to
the Horizontal circuits.
Posted on May 12, 2010
  • 21 more comments
  • vernon johnson
    it is 120v. good to hear from ya palaboy.
  • vernon johnson
    it is 120v on the b+ and the resistor i do believeit is in series.
  • Rommel Cana
    Rommel Cana May 13, 2010
    Would you be kind enough to give more and accurate details on your "sync ic has 55 volts on pin 9"?
    Please include the part number or the actual label on the component , so I can cross-check
    on the service manuals.
    What output voltages on the power supply have you got on:
    a ) when the unit is on standby?
    b ) when you try to turn it on ?
    c ) when it is turning off ( flashing )?
    Indicate also the number of flashes you are having
    These would narrow down our troubleshooting.
    i would not be able to have a better solution , if you only give an anonymous data.
  • Rommel Cana
    here are additional service tips for you:
    hope these helps,
    regards,
    palaboy
  • Rommel Cana
    More additional tips:
    Take note of the value of Resistor
  • Rommel Cana
    and here is your Vertical Def Circuits:
  • Rommel Cana
    Might also take a look at these:
  • Rommel Cana
    and another :
    Pin 9 should be 7V9
  • Rommel Cana
    here is more:
  • Rommel Cana
    +8V starts here:
  • Rommel Cana
    Might as well check the diode 6482, 6488 and the resistors
  • vernon johnson
    vernon johnson May 13, 2010
    thanks palaboy i will be back asap
  • vernon johnson
    vernon johnson May 15, 2010
    sensei i turned my g2 all the way to the left and it came on without all the ringing inside of the tube and it stopped shutting down so sudden and coming back on so violent like. it also does not go off with the three color guns in the middle of the set in a circular fashion.it now comes on like a normal set but it still has the slanted lines and still does not show picture. it goes off after about 15seconds. the number to the chip is tda9588r/n1/31133. power supply voltage when it is on is 154v and it is 164 v when it is off. the standby light does not flash but stays on continuously until it cuts off. 7480 has 4.8v on the emitter when measured with the multimeter. now it reads about 60v-peak when measured with an oscope. why is that?
  • vernon johnson
    vernon johnson May 17, 2010
    where are ya sensei?
  • vernon johnson
    there are no components on 3487(supposed to be 4.7 ohm). there has never been, even though it says that it is on the schematics. i measured the voltages across the spot anyway and recieved a 124v from main power supply(supposed to be 140v) there is 7.7v on pin 9 of 7200. 4.6v on 7480 in standby mode and 1.3v in on mode. measuring from collector to emitter.
  • Rommel Cana
    Rommel Cana May 19, 2010
    on the last image ( 7480 )
    you should have an output voltage of about +8V ( emitter )
    If it is lower, check the base voltage with respect to ground.
    It should be +8V plus 0.7V , so about +8V7,
    plus voltage coming from the diode 6486 via 3446 ( resistor )
  • Rommel Cana
    have a check on the zener diode as well ( connected on the base of the transistor )
    better yet, have them both replaced ,
    Post also voltage on the input ( collector ) 7480
  • Rommel Cana
    voltage @ diode 6486 = about 13V
    it is high enough to produce 8.7V on the base, unless
    Zener diode 6482 is bad
    output could be +8V ( 7480 ) , if input ( collector is
    more than +8.7V plus 0.7V so about a minimum of 9.4 V
    on diode 6488 ( collector of 7480 )
  • Rommel Cana
    there are three possible causes to drop voltage from
    diode 6486
    a ) bad diode
    b ) bad vertical out IC
    c )it also connects to diode 6467 see the diagram above
  • Rommel Cana
    you also have a high B+, Philips can work to as low as 95V , read my tip
    Flyback
  • Rommel Cana
    your objectives are :
    a) produce +8V on emitter of 7480
    b ) produce +13V on 6486
    Voltages are with respect to ground ( not the ground
    from the primary side of the Main power supply, but
    the ground on the secondary side ).
  • Rommel Cana
    Rommel Cana May 22, 2010
    post back, what you found.
    You may need to "Divide and Conquer ".
    Meaning you may assort to disconnect some of the load to produce the necessary voltages,
    to attain the output voltage desired.
    Of course the unit will not turn on , But in protection Mode, but you can measure the output
    voltages on the low voltage supply ( secondary side of the SMPS ).
    Just for locating the cause ( low output ).
    You may need also a Variac , just to trim down a little bit your B+ supply to Hor Def Circuits.
    Try lowering it to 95V.( just for troubleshooting purposes also ).
  • Rommel Cana
  • 4,889 Answers
That sounds like a protector failure. Can you please verify the model number? Its probably the serial number that you have mentioned. If you can get me the size of the set and the unit type(DLP, CRT or LCD projector type) then I can help you with locating the serial number.
Sai.
Posted on May 19, 2010
  • 12,061 Answers
Http://www.scribd.com/doc/22235836/LG-Training-Manual-LCD-TV-42LG70
http://www.scribd.com/doc/3585482/Philips-Training-Manual-TVHD-Chasis-L05HD
OK please, download use these Service training manuals so you can troubleshoot your set. You FIRST need to find out WHY< that 2 OHM resistor needed replacement, there must be a fairly serious, problem, may in PSU, that can cause a resistor of that size to fail. You need to go back, to the PSU, measure all the voltages and work out from there. The increased current required to cause the resistor to fault, will most likely have damaged any Transistor, IC, whatever attached, or fed by this resistor. You will have to fix the Fault, that caused the problem, as simply replacing the "bad part" still leaves the "Cause" that "Caused" that part to go bad, & fail, in the first place.. Always start ALL troubleshooting regardless of symptom, at the PSU, as if those Voltages aren't correct, nothing else can be.
IF you wish to try to fix it yourself, and I do not recommend it. FIRST, you Must get a service manual, then you need, equipment, an Oscilloscope is a MUST HAVE.(Perhaps, this could be done without, as long as there is no alignment, or waveform observations needed) Also a Multimeter, and soldering iron, a DE-soldering station, an anti-static wrist strap, (Any TV is extremely static sensitive). Now FIRST you must make sure the Power supply is 100% as if this is NOT then nothing else can be. Also there are safety considerations, any unit that can cause a Fire or Explosion, or both, needs to be attended to with the utmost care. As if it isn't done correctly, a catastrophe is indeed possible, Faulty sets can cause a fire, and a fire in the middle of the night, I believe is not good. And any person that has attended that set, will be held to account. Now with that understanding, I guess proceed if you wish. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Now if you feel that it you do not want to do it. It is my professional advice is to get you set looked at by a Philips Authorised Service Centre, and ask for free "Quote", this way, you will be able to make an informed judgment, as to repair or replace. As these days seemingly insignificant SYMPTOMS, often cost as much to repair as it may cost to buy.
Posted on May 05, 2010
  • 979 Answers
Hello vljenterp81, hi, try replacing low value capacitors with high voltage ratings, where the cathode is connected to ground, near the horizontal stage. if you have enough cash, try replacing the sync IC that produce the sync signal for both vertical and horizontal. keep me posted.
Posted on May 06, 2010
  • 666 Answers
The blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Posted on May 04, 2010
Can not get the colors to convergence
You will need to replace the 2 convergence ics and also check the 12 6.8 ohm resistors since they will usually blow when the ICs fail on a phillips. You can get the convergence repair kit for your phillips from www.tvrepairworld.com which contains the ICs, resistors heat sink paste and the CD with repair instructions.
Jul 10, 2011 | Philips 60PP9202 60" Rear Projection...
Color convergence
find the change value capacitors and resistors in the convergence section!
Oct 08, 2007 | Toshiba TP50G60 50" Rear Projection...
Don't have remote is there another way to line up colors I've already changed the convergence chips but not the resistors
Chances are the new ICs have failed since the 6.8 ohm resistors werent changed a phillips will almost always blow one or two of the 6.8 ohm resistors and if new ICs are installed without replaceing the resistors the new ICs are usually destroyed by the blown resistors. You will need the original remote or authorized replacement to adjust the convergence properly.
May 06, 2011 | Philips 55PP9401 55" Rear Projection...
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
Thanks, I posted a question regarding a convergence failure earlier. I followed your previous advice and replaced the STK392-110 and STK392-150 chips and the RK62 resistor which was bad, however the...
RK62 in this model is a 2.7 ohm 1 watt resistor (per the Hitachi site).
Let me ask you a few questions--did you check all the protect resistors? Sometimes you get one that looks perfect and is open.
Second, are you trying to adjust with the Hitachi remote in the customer menu or the TECH menu?
If in the customer menu you may need to go into the TECH menu and adjust and save there--if you get into the TECH menu and blue will not adjust somewhere--you probably have a bad resistor somewhere.
This all sounds familiar--I bet I helped you before--
SD TECH
Dec 29, 2009 | Hitachi 51F500 51" Rear Projection...
I just replaced the convergence board on my JVC AV-56WP74, but the red still won't line up. Are there other parts that should be changed?
you also need to check and replace low value resistors in that circiut.they are all 1 watt,usually they get discolored when stressed.R842 2.2 ohm,R854 and R846 1.5 ohm,R850 2.2 ohm,R858 3.3 ohm,R862 1.8 ohm.they must be the exact value available in MD from surburban electronics.please note stk392-110 upgrade to stk392-150 for future referance.ONCE AGAIN CHECK ALL LOW VALUE RESISTORS
Sep 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
Sony kp53v80 Red convergence stuck vertically
Did you replace the convergence ICs? The 4.7 ohm 1/2wwatt resistors and the pico fuses? Let me know and I will assist you, as often sonys will blow the 3.5 pico and a few of the 4.7 ohm 1/2watt resistors when the Ics fail.
Jul 28, 2008 | Televison & Video
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
