Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
How do I fix a stuck choke on my Poulan Pro 20 HP riding mower. It starts and runs, but not at full power and speed. If you open or close the choke cable there is no difference in how the engine runs.
5 Suggested Answers
jrw4u
  • 62 Answers
SOURCE: Craftsman Riding mower won't stay running
Well this could be a couple of things first thing first is check the air filter and make sure its clean you can blow it with air or pore gas over it and clean it make sure you let it dry before reinserting
second im assuming this is the first time you have used it this year if so the gas you have in it hasnt been sitting in it all year has it like anything else gas gets old
third alot of times you can let it run for a while with the choke out then slowly pushing it in
fourth you could have water in the gas remove the tank and empty it remove the spark plug turn the engine 4 or 5 times only bumping it dont hold it down this will blow some of the water out then dry the spark plug off and replace it
if this doesnt help it could possibly be carburetor problems
Posted on Apr 29, 2009
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
SOURCE: Poulan riding mower starts and runs for a few
If you have already changed your fuel filter and spark plug, look at your fuel tank cap. The breathing holes may be clogged with dirt or debris preventing good fuel flow. I happened to spend $150 bucks for this $5 fix. Hope this helps.
Posted on Aug 29, 2010
SOURCE: Just purchased a Poulan Pro Snow Thrower and on
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Posted on Nov 30, 2010
Poulan pro ppb350 weed trimmer stalls when choke is open
-After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
Because the engine need more air to burn the gas.
Good Luck
mai
Jun 06, 2014 | Garden
Craftsman ys4500 mower-- starts great and runs ok at low speed but at full throttle sputters and pops and of course loses power
sounds like your choke is not opening up all the way fast easy test,take a sharpe pen and mark priar adjustment on choke cable. next; remove cable from carb,then hold chokeopen start give full throttle{no difference} carb kit
Oct 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Poulan riding mower only runs if its primed and wont keep running
there is a solenoid on the bottom of the carb is that stuck is there power going to the solenoid a bad safety switch will cause no power to it
Apr 27, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Motor runs good, starts good, but smokes. do i need a gas treatment? thanks.
if its running with the choke stuck on it will smoke it will be black smoke if the piston oil ring has worn out you get blue smoke,,and you can smell oil in the smoke there is no treatment that fixes worn out piston rings,,,only fitting new rings will fix that
Jun 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
No power/rough idle/black smoke
either the choke is closed or the float is stuck open..if the float is stuck open, normally it will leak gas
Jun 23, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
140 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
