Question about Protron PLTV-4250 42 in. LCD Television
How do i connect my tv to my notebook computer
  • 755 Answers
You get a VGA cable from a local electronics or computer store and connect the laptop vga external monitor port *(its the 15 pin D shaped blue port) to your TV's VGA input *(also a 15 D shaped port).
Then, when you want to watch your computer on your tv. Change your TV input to computer and toggle the laptops video output *(usually by pressing the laptops FN key and one of the function keys that has a picture of a monitor on it simultaneously).
That should do it. And, if you want the picture on both displays the FN feature normally gives you that option if you press the buttons again.
Good luck and enjoy!
Posted on May 04, 2010
How do I hook my HP Pavilion Notebook up to this television?
You can connect via HDMI > HDMI if both have one, or VGA to VGA, VGA > HDMI all leads available on eBay. go to source and choose VGA option.
May 17, 2015 | Sansui 19 in. LCD TV
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
No S video, how do I connect computer to tv?
for it u need a tv card. then u can enjoying tv
Jul 23, 2009 | Computers & Internet
How to connect svideo cord to tv
You should have a little plug socket on the side of your computer or on your tower that has lots of little holes in it, there should also be the same on the back or side panel of your tv, only if it is a very modern tv though. Plug the cable into both the tv and the computer and then find your programme on the tv menu. On my tv it just says PC. I hope that this helps.
Jun 30, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Blu Ray connection on notebook to tv
i would go with the dvi or, avi pc inputs. this will mesh well with this Phillips.
Feb 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Connecting my laptop to tv
The first thing you should check is that whether your Notebook has a SVideo Port or not.
If Yes than you need the Svideo Cable which you can use to connect the computer to the TV.
Once that is done, In order to shift the Display from the notebook you need to use the shortcut. (Function Key + F2)
Note : Diff computer may have different shortcuts to shift the display.
It could be (Function key + F4 ) on HP
Hope this helps
Regards
Sammy
Jul 11, 2008 | HP Compaq Presario V2000 Notebook
I AM TRYING TO TURN MY JVC TV INTO A MONITOR FORMY LAPTOP BUT I CANT SEEM TO GET THE RIGHT CHANNEL. I KNOW ITS NOTHING TO DO WITH MY LAPTOP SO ITS TO DO WITH THE T.V. I THINK I NEED SOME SORT OF CHANNEL TO...
hi dear
Laptop Multimedia Ports Info
Component Video Out: Connects a TV or HDTV to your notebook so you can view high-quality, high-definition video streaming from the notebook. This three-piece connection (color-coded red, blue, and green) is the best method for sending video from your notebook to an HDTV or anything that receives component video. This connection allows the chrominance (color) and luminance (brightness) portions of a video signal to be processed separately, thus producing higher-quality video than an S-Video connection. S-Video works similarly, but component video improves color accuracy even further by splitting the chrominance signal into two portions.
Composite In/RCA: Connects a gaming console or camcorder to your notebook, for viewing video or playing games on the notebook. Color-coded red, white, and yellow, composite video input uses standard RCA-style jacks to connect your notebook to receive video and audio signals from your TV, VCR, game consoles etc.
TV Tuner/75-Ohm Coaxial: Connects a cable box, TV, or VCR to your notebook, so you can watch and record TV content on the notebook.
Sometimes called an Rf input, a 75-Ohm coaxial cable can carry video and stereo signals simultaneously. RF cable connectors (often called F-type connectors) screw onto the 75-ohm jack, are pushed onto it, or connect via a dongle that vendors usually supply.
S/Pdif/Dolby Ac3 Digital Out: Connects your notebook to speakers or a stereo receiver to play digital audio stored on the notebook. S/PDIF (Sony/Philips Digital Interface) is a standard audio-transfer file format, usually referred to as digital audio. This connection allows the transfer of audio without converting the signal to and from an analog format, which can degrade its quality. If you also have an S/PDIF In port, you can play digital music stored on an MP3 player through your notebook. The headphone jacks found on some notebooks double as S/PDIF Ports.
DVI: Connects a digital projector or LCD panel to your notebook to display in large format either video content or a PowerPoint presentation stored on the notebook. DVI (Digital Visual Interface) is a multipin connection used for passing standard-definition and high-definition digital video signals. It's found on HDTV tuners, a growing number of DVD players, HDTV-ready televisions, and some computer displays. DVI-D is the type of DVI connection found on most home video gear and carries digital-only signals. DVI-I is used with some computer video cards and can pass both digital and analog video signals. Some TVs have DVI-I inputs for greater hookup flexibility. DVI connections transfer video signals in pure digital form, which is especially beneficial if you're using a fixed-pixel display like a plasma, LCD, or DLP TV.
Firewire/ I.Link 400/ 1394: Connects a digital camcorder or external hard drive to transfer (but not display) large files, such as MPEG video, to your notebook. Also known as IEEE 1394, this is an extremely fast (commonly up to 400 megabits per second), two-way digital connection used for plugging in Your DV camera or other peripherals (such as an external hard drive or optical drive) to your notebook. It is used in digital camcorders because it is one of the few connections capable of quickly transferring full-motion video.
S-Video In: Connects a digital camcorder to your notebook to display video stored on the camera on your notebook's screen. Also, if your VCR has an S-Video Out port, you can transfer your VHS tapes to digital format. S-Video inputs use a four-pin jack to receive video signals from camcorders, gaming consoles, TV, or any device that has an S-Video out port. the S in S-Video stands for separate: S-Video connections transmit the chrominance (color) and luminance (brightness) portions of a video signal along different paths, allowing them to be processed separately, though S-Video does not produce as vivid an image as component video. This is a common way to display content from a digital camcorder or any device that has an S-Video Out port. (Firewire also transfers data files from your camcorder to your notebook, but it can't display video in real time on your notebook.)
S-Video Out: Connects a plasma or newer TV to your notebook to display video content streaming from the notebook. The most common way to connect a TV to a notebook, S-Video Out uses a four-pin jack to send signals from your notebook to your TV or anything that accepts S-Video In.
and use Fn+F5 or Fn + F4
to switch your ntbook to tv
oke
Mar 22, 2008 | Computers & Internet
Protron PLTV-4250 42 in. LCD Television Logo
71 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
