Question about Garden
We have a very steep grad on one side of our pond. riding mower lost traction and went in - engine partially submerged for maybe 10 minutes before pulled out. Have not tried to restart - wondering what I should do?
  • 2,100 Answers
It should fire right up. You won't know till you try. We had a water pump running on the dock jetting poles down in the mud. The pump vibrated off the dock and in it goes, running, I grabbed it by the hose and pulled it up, It fired right back up and kept on going. Never missed a beat. We thought it was going to **** in water and never run again. Honda's, can't beat em. Hope this helps.
Posted on May 04, 2010
18 hp craftsman 2000 smokes when cutting on a side hill
Wanda, make sure oil is not over full, oil in crankcase could be running to the intake of carb., valve guides or piston drenching an excess amount of oil on them causing the smoke. As long as mower does not smoke when driving on near level surface, mower should be OK. These engines were really not designed to cut on steep grades.
2 stroke engines, the engines with gas/oil mix are the mowers that are safe to run on hills as they will not starve or over lubricate engines. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
smoking at an angle
http://www.helpfulgardener.com/forum/viewtopic.php?t=37291
white smoke coming from riding lawn mower exhaust ShopYourWay
Jul 29, 2016 | Craftsman Garden
Tip
Safety For Riding Mowers
<span> <ul> <li>Do not give children rides on a riding mower, even with the mower blades not turning.</li> <li>Children may fall off and be badly injured or interfere with safe machine operation.</li> <li>Children who have been given rides in the past may suddenly appear in the mowing area for another ride and be run over or backed over by the machine.</li> <li>Do not mow with a riding mower in reverse unless absolutely necessary.</li> <li>You can be seriously injured or even killed if you use a riding mower on too steep an incline.</li> <li>Using a riding mower on a slope that is too steep, or where you don't have adequate traction can cause you to lose control or roll over.</li> <li>Always consult your operator's manual for safety messages concerning operation on a slope.</li></ul></span>
on Apr 02, 2011 | Garden
John Deere Riding Mower won't steer after a rollover accident. How do we fix? Or even know what to fix?
not sure but if it is mechanical steering I would look for a bent tie rod on either side and from the steering gear under the hood ..
Oct 16, 2015 | John Starter Deere Sst18 Spin Steer Deere...
John deere d110 clicks but won't start
Starter solenoid. 10 bucks. just fixed mine, exact same problem.
Nov 09, 2013 | John Deere D110 19.5HP Single Cylinder...
Brand new less than 30min on tractor when mowing down hill white smoke bellows out the exaust I imediatly shut mower down and am parinoid about restarting for fear of damaging motor.
how steep of a hill was it?steep enough for oil to go forward into the from of the engine roll it to a flat surface and check the oil level if ok run the engine and let it burn off if the hill ii's that steep then stop using it on the hill check the manual for running angles
Jul 10, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
Toro 22 inch Recycler Lawn Mower - would not restart, would make a clink sound when I turned the key. I tipped it partially on its side and tried turning the blade and it moved okay a little tight. Went...
If it runs, make sure the oil level is correct and continue to run the mower.
The blade should be a little tight, you are turning the engine.
Gary
Aug 14, 2011 | Garden
I am contacting you as I am a bit desperate for help. Please advise as to what should be done with regard to the Savio Skimmer Filter SS0000. At around 5pm when feeding the fish, I noted the skimmer...
This means that the filter or leaf basket is blocked. When the pump is off, the water levels will look fine, but when the pump pulls water through, even a partial blockage of the filter or basket limits flow so the level falls and eventually the pump 'sucks air'. Remove and thoroughly clean the leaf basket and filter. Good luck!
Aug 12, 2010 | Garden
Seat pressure switch cuts off engine when I lean to one side
I WOULD TELL YOU HOW BUT I CANT BUT YOU CAN TAPE IT DOWN AND TEN TAKE THE TAP OFF WHEN DONE
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Have a 19 hp john deere zero turn riding mower. starts up, blades turn, has oil. will not move forward or backward. does the hydrolic oil level have anything to do with that?
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off?
If so, this is your what is wrong traction motors
are disengage
Aug 30, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
