TV shuts off after about 15 minutes of running. Shows steady red light on lamp indicator.
  • herbmom03 Mar 26, 2008
    Our set is a WD-C657. We have only had it for about 3 months.
  • 8,617 Answers
Red indicator on the lamp is indicating the lamp is defective or the ballast isnt lighting the lamp. Try replacing the lamp. What model set do you have?
Posted on Mar 26, 2008
  • Sonny Berry
    Sonny Berry Mar 26, 2008
    Mitsubishi should still cover that under warranty. I would recommend contacting mitsubishi, they will send an authorized mitsubishi repair tech out under warranty.
6ya staff
SOURCE:
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Tv is turn on and red indicator is steady lit then after a minute the tv is turn off and red light is lit steady why,
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 08, 2014 | Panasonic 2 Projector Lamp
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
After replacing lamp the red lamp light remains on. Lamp will come on for a second then go out. About a minute later the red lamp light comes on and unit shuts off.
Check the lamp door to make sure it is seated properly I believe the red light indicates door switch problem. It shows you lamp error data in the service manual.
Feb 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Lamp goes off, LED steady red
I would call Epson support. Sounds like you have an internal fan problem.
Dec 27, 2006 | Epson EMP 730 Multimedia Projector
Televison & Video Logo
331 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
