Question about Intel Motherboard
Blue-red-pink lines over screen and BIOS
- Screen is covered with blue-red-pink vertical lines and dots
- Can't get higher resolution than 640 x 480 and color quality higher than 4 bit
- BIOS is messed up, some regular white-on-black letters are substituted by orange random ones ( like a to m, or ''''')
I've tried reinstalling windows - everything remained same.
Please, help :(
    Genius:
  • 1,027 Answers
Display section bad.
Posted on May 05, 2010
Whydo i have pink dots on my screen
Hi gailandst632,
I saw you post stating that you have pink spots/dots on your Screen.
to determine what the problem is we weill need to turn your computer off and boot into the BIOS screen.
1. Turn your Computer Off, then as soon as you power the machine On keep on tapping F1 on the keyboard to get the BIOS screen it will be a Blue screen with white fonts on it, in that screen see if the pinks dots are present or not.
2. If the pink dots are present in BIO then that means that the LCD screen of your Laptop needs to be replaced.
3. You will need to call your manufacturer regarding this concern check if your system is still in warranty, because this will be very expensive if you are out of warranty.
4. All manufacturers will cover a pixelated LCD screen if the dots or pixelated area has at-least 5 or more dots/pixelated areas on the LCD screen.
I hope that his will help you with the concern that you have posted.
Have a nice day.
Apr 05, 2011 | Computers & Internet
Why inkjet printers print slowly in high quality?
The reason they're slower in high quality is, as the sprays of colored ink are shot from fine nozzles through microscopic holes in the print head, more ink is required to complete each row of vertical pixels which are required in higher resolution ( more dots per inch ) photos.
The larger amount of ink must be dispersed at a slower rate causing the motor which controls the print head to move slower hence taking more time to complete a photo.
Lower resolution ( less dots per inch ) photos can be completed more quickly
because less ink is used and it can be dispersed quickly through the print head.
I hope this answers your question.
Feb 02, 2011 | HP Deskjet 6940 InkJet Printer
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Vertical screen lines and resolution is in extra large format.
Possibly either or a hardware fault..
Does the pc have an external monitor port? Most do.. If you can get another monitor, plug it up and use the correct hot keys (keys on your keyboard) to switch between the laptop monitpr & the external, it might help diagnose the problem. Maybe select a generic driver for the external monitor.. Although the pc will probably pick it up ok. If you need further help, let me know. Rgds.
May 02, 2008 | Dell Inspiron 8200 Notebook
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Poor resolution and pink blotches on desktop
right-click on your desktop. select Properties. click Settings Tab. under Screen Resolution slide to 1024x768 pixels. Under Color Quality, click the down arrow and select 32 bit. click Apply and then OK. if it prompts for confirmation, confirm/ok it.
Apr 01, 2007 | Acer Aspire 3000 Notebook
Intel Motherboard Logo
274 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
