Question about Compaq Presario 700 470024-192 Notebook
Transfer of old laptop's condent to external harddrive
When trying to install the external harddrive-i'm asked to insert windows 98 2nd edition cd-which I don't have. what can I do?????
  • 655 Answers
Windows 98 don't have pre-installed drivers for mass storage, like external hdd, pen drive, flush memory etc.
So, you should install the driver for your external hdd then win 98 will recognize it. And you can use it. For you external drive driver you can surf your external manifacturer site.
If any problem Ask me.
Thanks
Iqbal
Posted on Mar 26, 2008
Once removing my old harddrive and putting into a Amicroe USB 3.0 SATA External HD Aluminium Enclosure it asks to format before use losing all my harddrive i was trying to save. Is there a way to repa
What OS are you using? If this is a Windows system (or non-Apple, at any rate), what does the BIOS say about the HD size?
Something has become corrupt. You might not make it out "alive".
Sep 27, 2014 | Computers & Internet
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
Hi Andrea I have just connected a hard drive to my Laptop and it isn't recogized.. can you help. I'm running on Windows XP Thanks Ian
Not Andrea, just wanted to offer;
1) Installed a new larger Harddrive for the laptop?
There is a special procedure for this. Depends on what laptop we're discussing here.
A new harddrive will have no operating system on it. BIOS needs to recognize the harddrive.
{When you press the Power On button of your laptop, the first chipset to receive power is the BIOS chipset. BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the laptop over to the Operating System. WinXP is one example of an O/S }
Some laptops have a procedure where basic info is stored until the new harddrive is installed. Then the basic info is transferred to the new harddrive.
In any case I suggest going into the BIOS Setup, and on the main page see if the Harddrive is recognized.
It will be listed.
If it isn't listed you have to manually set the harddrive's parameters. (Type them in)
The Cylinders, Heads, and Sectors.
When BIOS recognizes the harddrive, then you can install Windows XP off of the Restoration Disk, (Repair. Also know as Non-Destructive Installation), or a fresh, new genuine copy.
2) If this is a reference to an external harddrive, there may be an electronic problem with the unit.
The main problem that happens with an external harddrive, is the small circuit board inside goes bad.
This small circuit board is an Interface Board.
It connects to the Harddrive inside the case of the external harddrive, and allows a USB cable to be used.
If this is found to be the problem simply remove the harddrive inside, and install it into an economical external enclosure.
Awaiting further information so I know what we are dealing with.
A) Is this a reference to a new harddrive being installed into the laptop?
If so, laptop manufacturer name, and Model Number.
(Bottom of laptop in a white Service Tag, or sticker)
B) Is this a reference to an extermal harddrive?
Manufacturer name, and Model Number
Regards,
joecoolvette
Oct 25, 2011 | Computers & Internet
I got an old laptop and I bought a new toshiba laptop I just wanna ask how do I transfer my application and files from my old laptop to a new one using external hardrive,also wat external hardrive,and also...
You can transfer the data files only from the old laptop to the new one. You cannot transfer the installed applications/software. Software are required to installed again on the new laptop afresh.
To transfer the data you can use external portable hard disk, which can be connected to the PC using any USB port (just like pen drive) and you can copy - paste the required data to the external disk just like you copy data from one partition to another. After copying the required data, you can connect the external drive to new laptop and copy the data to the new laptop. You can use external drive of any brand/ capacity. However, it is better to have an external drive with larger capacity, so that you can transfer the data in one go.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Toshiba Computers & Internet
How can i install my windows home edition software if the operating system is linux?
You will have to backup all data you want to keep, (on a usb stick or external harddisk) and then insert the WIndows disk.
Then restart the PC, and press [enter] when the computer asks whether you want to boot from disk. Follow the setup, and WIndows should be installed just fine!
If you have any questions, please ask them.
Dec 15, 2009 | eMachines eMD620-5133 Notebook
I want to be able to Mirror or RAID-1 on 2 different drives, then break the mirror and mark the second drive as an active boot drive. After looking around online, I realize that this process is more...
I understand now, and appreciate your taking the time to clarify.
1.Make a backup disk of the current harddrives contents. This is a Restoration Disk.
Has the basic needed files for the Windows O/S, (Repair), but will also allow for a Full Installation.
2.Desktop, not laptop:
Install two harddrives, put them in a RAID1 configuration. Forget about the 'mirror' image program. Leave them both in there in case of a harddrive failure.
3.Laptop, not desktop:
A.There are some laptops that you press a key, or certain keys, when installing a new harddrive, when the old one has hardware issues, or viruses render it unusable. These key/s are pressed, BEFORE the old harddrive is removed. Allows replacement of that harddrive.
There are some laptops that Do Not! There is a workaround.
The above is to replace that harddrive, and may be used to upgrade to a larger harddrive, IF, certain criteria is met.
B.Use an external enclosure, insert the new 2.5" harddrive. Connect the external enclosure to the laptop via the USB port.
Now use an image 'mirror' program such as DriveImage XML, (Free), to copy over the image of the old harddrive to the new one.
Insert the new harddrive into the laptop. You can use the old harddrive in the external enclosure as a Slave drive.
Still only allows THOSE harddrives, to be used on THAT laptop.
Don't be surprised if you have to Re-Activate the O/S on that harddrive. (New one)
C.RAID configuration on a laptop = No
You only have one interface connection for a harddrive, Generally.
IDE, or SATA
(Some gamer laptops use two hardrives internally. These are already configured in a RAID 0 configuration. More storage space. However, if one harddrive goes kaput, all information is lost. I do not believe you are referring to one of these)
http://www.runtime.org/driveimage-xml.htm
The above is only for reference. I have no working knowledge of this program, just know of it's existence.
Sep 23, 2009 | Microsoft Windows XP Professional
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Toshiba satellite a205-s5831 Received kernel data error. Hard drive has clicking noises. Programs ran slow. Chkdsk running now for over 15 hours and only on 11%..preplacing bad clusters.
When a harddrive starts clicking it's on it's way out.
Buy a new harddrive and at the same time get a USB to laptop harddrive adapter. You can reinstall XP with the recovery disks that came with your machine ans then slave your old drive to your laptop and recover your personal files.
If you really want to get technicalbuy an Apricorn housing: http://www.newegg.com/Product/Product.aspx?Item=N82E16817155602
And two new harddrives, fit one new harddrive to the Apricorn housing and try to install the EZgig cloning software to your dying Windows. You can clone your existing Windows install to the new harddrive in the Apricorn housing and then move that drive to your laptop, the second new harddrive can then be fitted to the Apricorn housing and used as an external harddrive.
EZgig comes with the Apricorn housing and you could even go so far as to create a clone of your Windows install to the new external harddrive. The Apricorn housings are excellent, they are small enough to carry in your laptop case and all they need for power is a USB port.
Sep 01, 2008 | Toshiba Computers & Internet
Plugged in USB device before installing proper software
you can also inserting the cd/ dvd in rom of your laptop then it will asked the windows installation then instakk windows
May 26, 2008 | Microsoft Windows Vista Ultimate Edition
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Compaq Presario 700 470024-192 Notebook Logo
95 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
