Question about HTC Touch P3450 Smartphone
ActiveSync not working
Everytime i have to hard-reset my htc touch 3450, i have to re-install active sync. Create new partnership profile and use it. But this time it stopped working. i am not able to sync. pls help
Rgds
Sandeep Vats
  • Sandeep Vats Mar 27, 2008
    Ok, i got it solved, un-installed the activesync from my laptop, removed the Microsoft ActiveSync folder from programs. Removed the profile from my htc phone. Re-installed the activesync and it started working fine. now.
  • HTC Master
  • 13,433 Answers
Try difrent usb ports.
Posted on Mar 26, 2008
I need htc touch viva driver
Drivers are included with the microsoft software you use to sync eg.
Windows Mobile Device Centre. WMDC.
Or
Microsoft active sync.
You can get 32 bit version of WMDC ...HERE... 64 bit ...HERE...
and Microsoft Active Sync 4.5 ...HERE...
Although Microsoft seem to be having issues with the connection of HTC's to their software and their help department doesn't appear to be much help.
If you already have the software installed. Try uninstalling and downloading fresh copies and re-install.
Also make sure you clear your partnerships in your phone as HTC only allow 2 sync partnerships.
Jul 17, 2010 | HTC Touch Cellular Phone
Cannot sync, connot create relationship (no active
if u've windows 7,try windows mobile device center.also try using different USB ports 4 partnership.
Mar 16, 2010 | i-mate K-jam Smartphone
Contacts do not sync with my phone
In your phone go to START-Settings-Connections-USB to PC. When there choose ActiveSync and make sure that "Enable advanced..." isn't ticked. Then open WMDC and end partnership. Restart PC open WMDC and do new partnership.
Jul 25, 2009 | HTC Touch HD Smartphone
HTC HD and MS Outlook Notes
Unfortunately, Notes are not available using Exchange ActiveSync, yet.
You have to tether your phone to a PC with Outlook and ActiveSync (XP) or Windows Mobile Device Center (Vista) installed.
Since mutiple ActiveSync partnerships are supported you can sync some things with Exchange and some with your PC.
If we are lucky Windows Mobile 7 and/or Exchange 2010 will make this possible.
May 21, 2009 | HTC Touch HD Smartphone
.msi in HTC
Hi. You can download Microsoft ActiveSync through this adress: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/ActiveSync-download.mspx) After you install this software, just plug your PDA into your computer with the USB cable, and run the .msi. After the installation completes within your computer, ActiveSync should run and install the software to your device also. Hope this helps.
May 20, 2009 | HTC Touch P3450 Smartphone
Serious Issue re ActiveSync 4.5, HTC Touch, WM6
by what i have seen when i have that problem i have deleted the partnership from active sync and then recreated the partnership, be sure that you have all your info backed up though because it will wipe it all off. That should help if not let me know
Mar 02, 2009 | HTC Touch HD Smartphone
How to soft reset
There is small button that is usually in the battery compartment that you can press with a paper clip to soft reset the phone.
However, a soft reset will not fix your ActiveSync problem.
Here's what to do:
Open ActiveSync and go into the settings/options.
Delete any partnerships you see.
Now verify the following settings with your Exchange Administrator to make sure you have them right:
Server name: (a.k.a. your public server name)
Use SSL: Yes or No
User name:
Password:
Domain: (a.k.a. your private Windows Domain)
Now verify that your Exchange Admin has enabled ActiveSync for your account.
If the settings are correct and ActiveSync is enabled, you should now be able to set up working ActiveSync partnership.
Jul 04, 2008 | HTC S710 Smartphone
Removing/restoring partnership
acc to me, partnership once deleted due to hard reset on ur smartphone will not be created under the same name until u delete the same partnership from active sync on pc. To delete the partnership open active sync>file>delete partnership..then create new with the same name with ur smartphone.
hope this will help
Sep 19, 2005 | HP iPAQ HX4700 Pocket PC
NO file transfers are working!
Try deleting the partnership in ActiveSync on the PC, and then create a new partnership. I saw this problem, when I connected the first time to a PC. I tried connecting to a second PC, and had no problem. When I went back to the first, it required that I create a new partnership, and no problem with the connection.
Sep 14, 2005 | Dell Axim X5 Pocket PC
HTC Touch P3450 Smartphone Logo
178 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
