Question about Akai LCT3285TA 32 in. LCD Television
I have a 32'' Akai LCD Television with a sound problem. If I hook up cable through the RF input I get a great deal of sound static and clicking noises. If I hook the cable up through the HDMI input the sound is fine. What can I do to fix the RF input?
    Scholar:
  • 70 Answers
The unit will need to have the tuner module replaced. In some cases you can get the board that you need from www.shopjimmy.com Swapping a board out is not complex so you may want to do that yourself. Otherwise the unit will need to be repaired by a technician.
Posted on May 04, 2010
Can you hook up a digital converter to a akai model num lct3201td 32 inch tv
The converter box connects to the antenna input of your TV or, for better picture quality, L audio, R audio, and video outputs from the box can be connected to corresponding inputs on the rear of your TV.
Nov 02, 2016 | Akai LCT3201TD 32 in. LCD Television
Cable to tv cant find tvs cable port
fisrtly check for a rf connection on your tv. if you cant find it buy a converter rf to a/v, this will help you to input your cable and have a/v out put which you can connect to your tv.
Jan 04, 2010 | Akai LCT3201TD 32 in. LCD Television
How do i hook up coaxial cable
Straight into the RF connector on the tv. If you have a converterbox, satellite or cable box,connect to the input, box first, and then from the out point from box into the RF connector of you TV. Hope this works!
Nov 29, 2009 | Akai PDP-4247 Television
The sound from this TV is terrible both with surround sound on and off. There is constant static on many channels. Can this be fixed?
That kind of problem is difficult to figure out without getting into the TV, but my guess would be a problem in the tuner. It can be fixed by replacing the tuner, or the tuner board. You can verify if it's the tuner by using an input other than the RF input to the tuner to see if it clears up. Try a DVD into the component inputs.
If you use a cable box, or satelite reciever, the sound problem can also be originating there. You can rule them in or out by trying the DVD in the component input test mentioned before.
Good luck.
Nov 29, 2009 | Akai LCT3285TA 32 in. LCD Television
When hooking my direct tv into the coaxl in it does not work ? When I use the AV cables it works. and I do try all inputs.What can I do
If the coax RF OUTPUT cable of the direct TV BOX is set to channel 3, the the TV will have to be SET TO TV CH3.
Nov 02, 2009 | Olevia LT32HVM 32 in. LCD Television
Has sound but no picture
try a different rca cable, or even putting into a different input. Example, if you have dvd player hooked into input 2, and you have a input 3, try your connections there and see if you have the same problem. If so, use a different rca cable or whatever your cable maybe that you are using :-)
Apr 07, 2009 | Akai LCT3701AD 37 in. LCD Television
Akai LCT3285TA-need stand-remotes and 1 component input dont work
Check it out, is that remote you need for your Akai TV?
HERE is another remote but I'm not sure.
Dec 18, 2008 | Akai LCT3285TA 32 in. LCD Television
I need help tv lcd akai model lct2785ta
You do know that this model TV takes about 5-10 seconds to come on after you press the on button, right?
Press it once to get the green LED, then wait. If it doesn't display the blue AKAI splash screen within 15 seconds, the TV is not working as it should.
Also remember that this model has two RF input jacks. As seen from the back of the TV, the jack on the far right is the one to use for analog TV, analog cable, coax out to TV from a cable box, or rf out from a vcr.
Don't use the one on the far left. It is for input to the ATSC OTA DTV tuner only.
Most likely there is a real problem with your TV, but in the video, you are pressing the on/off button in rapid succession. That will never work with this model.
Jul 12, 2008 | Akai LCT2785TA 27 in. LCD Television
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Akai LCT3285TA 32 in. LCD Television Logo
107 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
