Question about DeVilbiss Pressure Washer Adj Wand 1612" Long
My power washer starts but will not keep running.
EXVRB 2321 Excell power washer starts but runs for just a few seconds. What causes this?
Fisher and paykel keeps blowing fuses, code 37, I have replaced the pump already
Yes the original bad pump has damaged the drain pump circuit on the control board.
Dec 20, 2016 | Fisher and Paykel Washing Machines
Xtreme pressure washer keeps cutting out.
If it is a gas powered machine and it cuts out when you release the spray gun trigger, it means that your unloader valve is stuck closed.
It would help to have more information about your machine and your problem. Gas or electric? Does it start up and run fine or cut out a few seconds after starting? Does it cut out when you release the trigger?
Does it cut out while spraying?
May 07, 2014 | Garden
Weak Pressure. I have the power washer running for a few minutes, then I go to pull the trigger on the wand and I only get about 1-2 seconds of full force pressure. The machine is still running (not as...
Check for a clog.
take the hose off the washer pump and start it. if you have good water pressure then you may have something on the hose or the wand. I had a lizard in mine that caused that problem before.
Sep 11, 2013 | Karcher Garden
Reciever keeps yurning itself off after a few seconds
Assuming running from a cold start,
it means protection circuit are activated.
If it runs hot, then turns off then it is thermal cause.
Simple solution could be disconnecting all your speakers
and power up.
If it runs OK, then reconnect one at a time to find the cause.
If disconnecting the speakers doesnt do anything,
these unit needs repair.
Start checking out power supply
Check the supply rails to the main amp ( B+ and B-)
and most important , check for DC offset voltage on all amp outputs.
Let me know if you need further assistance!
Sep 27, 2012 | Kenwood Audio Players & Recorders
I just bought a 2nd hand honda excell psi max vr 2522 2.2 gpm max 5.5 hp gvc160. i put gas and oil and it wouldn't start?
Have a helper hold the trigger of the wand open while you try it again. If it starts that way you have a sticky unloader valve in the pump. DO NOT RELEASE the trigger for more than 10 seconds if the engine continues to strain when released! If the engine doesnt run freely when you let go of the trigger, pull it again and shut down the unit!
Add some power steering fluid to your supply hose (about 3 or 4 ounces at a time) and restart the unit with the trigger pulled. Allow the oil to flow through the pump for 1 - 2 minutes for each treatment. Several treatments should make the pump and valve happy again.
Hope this helps.
Sep 25, 2009 | Karcher 2500 PSI Pressure Washer
EXCELL VR2500 power washer runs and then stops
I had the very same problem and nobody could help me until I was talking with a co-worker. Its a very easy fix. I couldn't believe it. I did this yesterday and it ran like a charm. You can either replace the head gasket or just by a good sealer to use on your existing gasket or replace it. I use Indian head gasket sealer on mine. The bolts on the bottom were lose causing a loss of compression. If you need more info you can email me (for free) and I will tell you exactly how to do it. Agr8flson@aol.com
Jul 07, 2009 | Karcher 2500 PSI Pressure Washer
Excell VR2522 Pressure washer - sudden loss in pressure.
Leaving the engine running for more than two minutes without releasing pressure trigger causes aluminum pump to overheat and causing damage to the purmp, resulting in sudden low pressure. (see page 9 in manual)
Jun 18, 2009 | Karcher 2500 PSI Pressure Washer
Washing machine
Pressing and holding the two centre buttons ie on/off and start/cancel together for a few seconds causes the machine to run in 'test' mode. Doing the same again puts it back to normal wash.
I nearly called an engineer once because my daughter causes it all of the time!
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
DeVilbiss Pressure Washer Adj Wand 1612" Long Logo
113 people viewed this question
Top DeVilbiss Garden Experts
Dennis Key
Dennis Key
john h
Are you a DeVilbiss Garden Expert? Answer questions, earn points and help others
