Question about Toshiba Satellite A105-S4334 Notebook
I need to install a new hard drive .. how do I do
I need to install a new hard drive ..what do I need to do that?
  • amanda_bill May 05, 2010
    I have the new hard drive itself installed, I just need to make it work. Sorry if I did not make myself clear...
    thanks
    thanks I will try this... any suggestions on how to get the memory off my old hard drive with out paying some one A LOT of money??
    President:
  • 524 Answers
  1. urn the laptop over. Position your laptop in the direction so that the Toshiba label, on the bottom of the hard panel, is facing you. Your Toshiba label is positioned correctly if it is positioned on the upper-left side of the external hard panel. Remove the battery pack from the bottom your Toshiba laptop to be sure it is powered off.
  2. Step 2 Remove your laptop's external hard panel. This panel is the external plastic layer on the back of your computer to cover and protect your computer's most important hardware components. The screws you need to remove are located on the four outermost corners of the bottom of your laptop. Follow the chart guide listed in Tips for screw and screw driver compatibility and removal. Distance your screws from your workstation to avoid mixing them up and/or losing them.
  3. Step 3 Locate your hard drive panel drawer door when you have totally removed the external hard panel. It is located where the smaller door in the bottom-right panel was before your removed the external hard panel. Your hard drive will be locked into this specific drawer door and the computer itself. Completely unlock the hard drive and remove the drawer from your laptop.
  4. Step 4 Remove the entire hard drive from the drawer door. Hold the hard drive on all sides to ensure that you do not drop it. Place the removed hard drive in an enclosure area to avoid damage of any kind.
Place the new hard drive in and put it back up.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 04, 2010
  • CIROC TECH SUPPORT
    CIROC TECH SUPPORT May 05, 2010
    hello,
    if you already had install a hard drive its not install correctly
    Restart your laptop and follow the instructions in your owner's manual
    to enter your system's BIOS. If the new hard drive is installed
    properly, it will be recognized by the BIOS.
    Step to Get to bios
    Power up your system and press
    the delete key during
    the DOS memory check to access your computers BIOS settings.
    Select
    the hard disk detection menu item. You should see your
    current C:
    drive settings under the primary hard drive master. Write
    these down
    on a piece of paper for safe keeping and do not change them.
    Go on to the configuration of the primary hard
    drive
    slave. Your BIOS should auto detect your new hard drive and
    give you
    its settings. If the BIOS correctly detects your drive it
    should report
    the drives capacity correctly. If it does not detect your
    drive, you
    will have to manually enter the correct settings for your
    drive which
    includes the number of cylinders, heads, and sector of your
    drive.
    Write down these settings and save them in case your BIOS is
    ever
    corrupted.
    Once your hard drive is configured, exit the
    hard drive
    configuration area and select the main BIOS configuration
    menu item.
    Make sure your BIOS is configured to boot off of the A:
    drive first.
    Save your BIOS settings (press the F10 key and type "Y")
    and the computer will reboot.
Where can I get user guide for unidentified hard drive?
PDF]My Passport User Manual - Western Digital
www.wdc.com/.../4779-70...
WESTERN DIGITAL TECHNOLOGIES INCUSER MANUAL. ABOUT YOUR WD DRIVE - 1. About Your WD Drive. Welcome to your My Passport® portable hard drive, an elegant, high-capacity storage.
Sep 15, 2015 | Computers & Internet
Installing a new blank hard drive in a DesignJet T1100,T610
The T610 hard drive is the formatter and has a special operating system software installed on if from HP. You can't format a hard drive and install it...so the whole formatter assembly needs to be replaced when the hard drive goes bad...
Mar 15, 2014 | HP Designjet T610 InkJet Printer
How to Reload WIndows on a New Hard Drive?
You don't need to remove a hard drive to install a new operating system. You need an operating system reinstallation disc to do that. You can find a lot of tutorials on how to install windows 7 in youtube.
Mar 22, 2013 | Toshiba Satellite Computers & Internet
I have a dell latitude E6400 that will not reboot. Can I buy a new hard drive for it....will that work..............
Hello
you dont need to buy new hard drive until you confirmed that your hard drive has no more, for the purpose you need check in CMOS setup, if it is detected by computer then there is a chance to re-use the hard disk, you just need to re-install windows, during installation format the hard disk after re-partition.
if this method fails then you need to buy new one, good luck
do rate the solution if got help
Dec 11, 2010 | Dell Latitude E6400 Notebook
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
Sir, Good day! How to reformat my hardrive toshiba dynabook without dvd drive
You'll need to remove your hard drive, hook it up to another computer via a USB to Hard Drive adapter and use the operating system of the other computer to reformat the hard drive. This will only reformat the hard drive, not install a new OS. To install a new OS you'll need a DVD-ROM and OS installation disc, or a flash drive with an OS installer on it to install from the flash drive.
Mar 25, 2010 | Computers & Internet
Install new hard drive m280e
~er~ what do you wanna to say ? how to install new hard drive?
if yes,you can reference the article :Illustrated how to replace a laptop hard drive
hope it can help you
Jan 13, 2010 | Gateway M280E
I recently installed a new larger, hard drive, but numerous problems have developed with it. Can I reinstall the old hard drive and pick up where I left off?
When you install a new hard drive you need to install also a software to make your drive working. The new install hard drive does now contain a copy of windows software.
Dec 10, 2009 | Dell Dimension™ B110 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
I need installation instructions for a new hard drive
Here is the quick guide to installing the new sata HDD.
http://www.easeus.com/resource/install-sata-hard-drive.htm
Jun 09, 2009 | Computers & Internet
Toshiba Satellite A105-S4334 Notebook Logo
378 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
