Question about Sony Playstation 3 (PS3) Console
Hdmi doesnt show picture - Sony Playstation 3 (PS3) Console
  • brad ackman May 05, 2010
    yes HDMI worked before 1 and 2 ports Ive checked with another device works fine I came home to do a D/L and then when done it did not show picture at all through HDMI
  • Jesus Bryan Soriano
    Jesus Bryan Soriano May 11, 2010
    Where was your PS3 connected to? Did it work before or this is just the first time you are going to do it?
  • 27 Answers
A few things to check. 1) does the TV tune to the appropriate HDMI port? If not then it isn't detecting a signal from the PS3. In that case you may not have HDMI output turned on. If you can reconnect the A/V cables then go to the system menu to display and set the output correctly. Start with 720p and work your way up to make sure you don't set it to a resolution that your TV can't handle. If you don' have the A/V cables then boot into safe mode and reset to default. This will reset the PS3 to out of the box settings (no data lost).
Posted on May 05, 2010
  • whitewolf4x4 May 05, 2010
    by download I assume you mean system update. If so then you are now afflicted by the 3.30 update bug. A huge chunk of us are affected by it.
    I wrote out all the details I have here: http://www.fixya.com/support/r4673943-ps...
    Otherwise I am not sure what it could be.
Dell insperon 1525 no sound or picture to tv with new hdmi cable connected , it worked fine yesterday but now i can get nothing , it doesnt even show on the tv that the laptop is connected to the tv
When you connect the laptop to the tv with the HDMI cable you will need to press function and F1/F2 depending on your keyboard layout. It is the key with 2 screens on it.
Once you press that windows will show you options for changing displays like Duplicate, Extend, Monitor, Projector(in this case Projector is the TV)
And for audio, you will need to right click on the volume mixer in the system tray and say playback devices. Click on the hdmi one and say set as default.
When this is done, everytime you plug in the HDMI to the TV it will automatically play audio from the TV.
Mar 02, 2011 | Dell Inspiron 1525 Laptop
No signal being reached
I'll give you the short answer. Your receiver is either version 1.1,1.2,1.2a,or 1.2b. None of which ever function correctly. HDMI is riddled with issues. The current version is 1.3b and I havent seen any issues "Yet". Best way to solve the problem is to run sources directly to the unit and run audio via digital coaxial or optical to your receiver. If you want the long version of all the HDMI issues, you can google "HDMI forums" and there are lots! Hope this helps. If you still need some help, post a comment and I can help more.
Aug 23, 2009 | Audio Players & Recorders
Console starts up and I can hear but shows no picture.
make sure video cable is plugged in all the way on back of ps3. the a/v cable is little tricky. it looks like its plugged all the way but its not. also if doesnt work, if u have hdmi cable use it then go to display settings, then connetions. set it up as av cable connection then it will ask about audio - av rca connetions. and save. now its set up as av cables and then when u use hdmi it will automatically set up hdmi.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My PS3 console doesn't display picture.
when the ps3 is on standby (red light) , keep the [ower button pressed at the front until between 5-10 seconds, until it beeps the it should work
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Xbox 360
If it has a hdmi cable and you or a friend has a tv compatible try and get a picture from their.
It sound that you might have a faulty cord for the video, or possibly the video drive has gone out on the 360, witch is a reported problem on many consoles.
Try to use b/g/r or the hdmi.
Is your switch on the correct location?
Av or High deff.
Good luck
Sep 11, 2008 | Microsoft Xbox 360 Console
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
My cable box doesnt recognise my hd tv when i hook up the 2 with an hdmi cable
Check operations manual for HDMI hook up. Some cab/box have to be switched from menu. If you can't use HDMI, use component cables instead, there's not much difference in picture quality. Possible bad HDMI cable
Apr 21, 2008 | Televison & Video
Sony Playstation 3 (PS3) Console Logo
137 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
