Question about HP Pavilion Elite m9426f Desktop
How do i unlock the signal from my wrt54gs v.6 on the other computer
If i installed an additional security system do i need to install that wep to use my router to play xp live
Posted on Jan 10, 2009
    President:
  • 778 Answers
You will need to use the same WEP (Wireless Encryption Protocol) Key that you used on the other computer. Or, you can press the reset button (located on the back of your Linksys router) for at least 10 seconds while powered on to reset it to default (unsecured wireless network), and then readdress your router (by typing 192.168.1.1 in the address bar of a browser) to set up your security with a new WEP (Wireless Encryption Protocol) Key.
I hope this helps, and Good luck.
Posted on Mar 26, 2008
I just installed a wirelss linksys wrt54gs v4 router in the bk bedroom, with my office computer equipment,,my wife has a wireless hp pavilion 6000, that she would like to use in the living room,40 ft away...
Hello
Try updating the firmware on the router.You need to log into the router using 192.168.1.0
Username =admin
password = admin or the word password.
Once in the routers home page check for updates and download and install.Also be sure any firewalls are not blocking the signal.
While your in the router set up a personal wep key for your wireless security.
There is a possibility your lossing signal to outside intruder.
Apr 21, 2011 | Linksys Wireless-G WRT54GS Router...
Tip
How to Unlock Addresses on your iPod Wi-Fi
<p>The iPod touch has a built-in wireless network adapter that allows you to join Wi-Fi networks; however, in some cases the wireless access point to implement a Wi-Fi network can be configured to an iPod touch join the network. You can configure the access point so that it no longer blocks the iPod from the wireless network. <br /> <p><br /> <p>1. Tap "Settings," then "General" on the iPod touch. Touch "About" then scroll down to "Wi-Fi address." Make a note of the 12-digit hexadecimal number listed under that title, which is the address of Medium Access Control encoded in iPod. <br /> <p><br /> <p>2. Connect your computer to a numbered port on the back of the wireless router using an Ethernet cable. <br /> <p><br /> <p>3. Log on to the computer. <br /> <p><br /> <p>4. Start a Web browser on your computer. Directly to the router's configuration utility. The tool is listening on a specific web address that depends on the router. For example, if your router is a Linksys WRT54GS, navigate to the address "192.168.1.1". <br /> <p><br /> <p>5. Open the configuration menu for the MAC address filtering. For example, in a WRT54GS, click on "Wireless" then "Wireless MAC Filter". <br /> <p><br /> <p>6. Remove the iPod's MAC address in the list of prohibitions aimed at the router's configuration utility. For example, in a WRT54GS, click "Edit MAC Filter List". A new window will appear. Double-click the field that the iPod has the MAC address, then press "Backspace" to make the contents of the field. Click "Save Settings". The window is closed. Click "Save Settings" in the main browser window. At this point, your router will be configured for iPod touch for the network. <br />
on Jul 21, 2011 | Computers & Internet
Looking for pdf owner manual for wrt54gs ver. 6 wireless-g broadband router
Feb 05, 2011 | Linksys Wireless-G WRT54GS Router...
I have a clearwire modem. I have to locate it 80 ft from my two home desktops and laptop. i need to know how to best do this. i have an e2000 router that i was hoping to use a wre54g range extender...
The Linksys E2000 router is N series router and the WRE54G is G range expander.
WRE54G is only computer with the WRT54G and WRT54GS routers.
You have E2000 router. I believe that router is capable of broadcasting the wireless signal upto 100 fts.
As Linksys says that router is capable of signal up 200 - 300 fts, but it is not.
You can try changing the wireless channel on the router to increase the signal.
Open the setup page of the router.
Go to wireless tab and change the configuration view to manual.
Try changing the channel to 11, 9, 6 ,1. See if that works.
Click Here for more information about the routers and network
Oct 02, 2010 | Linksys Computers & Internet
I have both a WRT54G v2.2 and a WRT54GS v6. Same Power Specs?
I have the Linksys WRT54GS ver 6 wireless router. It uses a 12VDC power supply @ 500mA. The center of the post is + and the outside of the post is -.
May 10, 2010 | Linksys Wireless-G WRT54GS Router...
WRT54GS - freq signal loss!
Sounds like you need to download a firmware update for your router, download the firmware to somewhere like your desktop, then browse to 192.168.1.1 and loginto your router and look for the update firmware link, browse to your downloaded file and update your firmaware, make sure you dont cut the router off or unplug it while it is updating.
Hope this helps,
David
7.2 http://downloads.linksysbycisco.com/downloads/WRT54GS-v7.2_fw,0.bin
7.0 http://downloads.linksysbycisco.com/downloads/WRT54GSv7_7.50.5_fw_US_code,0.bin
Mar 10, 2009 | Linksys Wireless-G WRT54GS Router...
I need to set up my linksys WRT54GS. do i set it up on my laptop or desktop? or both?
When you set up your router do always use a wired computer (phisically connected ).
You'll be setting up the router so setting it up through one is enough
Once the router is set up by performing these options
1>start->run->cmd ->youll find default gateway
2>open rsp by typing in default gateway address in brouser tab
3>select ->connection type ->and put in your uname and password for dsl or clone mac address for cable
4>set channell to 11 or 6 for best signal strength
5>set ur ssid(network name) and security (wep preffered) if you want it.
6>once router is set up on the top of the rsp you may see ipstatus:: connected
7>Now just select your network on your laptop
and happy surfing
Let me know if your issue is sorted
Feb 26, 2009 | Linksys Wireless-G WRT54GS Router...
WRT54GS version 6
Go to the linksys website at www.linksys.com, select your router, and you should find a link offering a driver download.
Apr 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS not detected
I am having the same problem with the WRT54XG4 but i discovered that if you disconect the internet port of your router and leave the ethernet port conected to your computer. You can access to the router and you can upgraded.
Hope it help you
bye
Feb 24, 2008 | Linksys Wireless-G WRT54GS Router...
Router to computer issues WRT54GS
Ensure that any firewall you may have is turned off, then try it again.
Oct 26, 2007 | Linksys Wireless-G WRT54G Router
HP Pavilion Elite m9426f Desktop Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
