Question about Plantronics Explorer 330 Headset
Recently headset has had an intermittent high pitched chirping sound while talking which occurs about every 15-20 seconds. What might be the cause
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
It may be feed back from the surround sound or speakers in your home, car etc. Try sitting away from them. If that does not work, delete from your cell phone and re-pair back to your phone. Hopefully that will help.
Good luck from Headsets Direct!
Posted on Nov 22, 2011
High-pitched chirp at same time every night
High pitch noises are very difficult to isolate. Since you have replaced the refrigerator, I would look for something else in the immediate vicinity that might be generating the sound.
Feb 16, 2014 | Refrigerators
High Pitched ear ringing sound coming thru somewhere up front by navigator system
Some things I would check are do you have blue tooth in operation. Do you have any form of michrophone in the cab as it sounds like a feed back problem coming through your speakers. Talk to a radio techie to see what he thinks
Feb 23, 2013 | 2008 Jeep Grand Cherokee
High pitched sound when attempting to use the headseat rather than the handset. I have tried all of the settings on the side of the desk moduel.
It sounds like it may be plugged into the wrong jack on the phone base. The cord from the S10 HAS TO BE plugged into the jack where the curly cord from your phone was plugged in. You can't use the headset jack, this will cause the high pitch sound you are hearing.
Dec 13, 2010 | Plantronics (45647-04) for S10, T10, T20...
Blinking green light in front, high pitched chirping noise, no picture.
u may have a high voltage problem , 1 may be the flyback transformer , or may be u vertical circuit , need to take it to do tv shop for service
May 08, 2009 | Televison & Video
NO PIC & NO SOUND ONLY HI PITCH SOUND SURGE FROM BACK
Goto the site www.TvRepairKits.com and get their "chirping" TV repair kit. It will fix the problem of the dead set with high pitch sound or chirping sound.
Jan 01, 2009 | Philips 43PP9202 43" Rear Projection...
Intermittent static in webcam recordings
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Nov 02, 2008 | Labtec Webcam Pro
No av-input picture with sound
Sep 25, 2008 | Philips 60PP9363 60" Rear Projection...
High pitched car sounds
does the noise and light occour at the same time ? another cause of a high pitched noise can be slipping drive belts, alternator,powersteering etc so check them for tightness, condition etc, does the noise happen when car staionary and just rev the engine ? if so i would say it is the drive belt/s, go back to the VW dealer re the ABS light and get them to check the OBD as should be done as part of the service , hope this helps
Mar 29, 2017 | 2001 Volkswagen Jetta TDI
I have a Philips TV Mach3Line 29 inch 29SX8771/75R that wont power up. No Picture, No sound, no power LED, just a high pitched chirp sound every second (not coming from speakers). Is it likely to be worth...
The chirping sound indicates the power supply is starting finding a problem and shutting down hence the cycling trip can be caused by any number of faults but I would first try the Line output transistor for a short collector to chassis if this is ok then Philips TV are prone to the small blue high voltage capacitors (2/3 Kv.102k/222k) becoming short usually indicated by being burnt or very discoloured.. If you are not technically minded its best left to a Tech.. Hope this helps.SUPER8
Jul 20, 2008 | Televison & Video
Awful High-pitched Noise and Echo Feedback
Jan 17, 2008 | Microsoft LifeCam VX-6000 (68C-00001)...
Plantronics Explorer  330 Headset Logo
214 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
