Hotpoint W321 flashing lights - washing machine
Hotpoint WF321 flashing lights - washing machine won't work
    Scholar:
  • 119 Answers
I have the same machine and it's the 2 solenoids for the cold water inlet at the back. I took the top cover off with 2 screws at the back and the 2 solenoids are connected by 2 screws. I dont know the price as i cleaned mine by flushing fresh water through and the spraying a little wd40 into both parts and it works fine now or just buy new part it's easy to fit but make sure always the mains is disconnected.
Posted on Jul 28, 2012
mumma_1
  • 903 Answers
SOURCE: wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Posted on Nov 24, 2008
localwonder
  • 6784 Answers
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
Posted on May 22, 2009
beltronic205
  • 1456 Answers
SOURCE: hotpoint wf321 1200 spin on off flashing plus
You could try its not too little in drum, out of load balance...
Posted on Sep 29, 2009
  • 3 Answers
SOURCE: All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Posted on Oct 27, 2009
  • 51 Answers
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
AQUARIUS WF321
Capital letters make reading tedious............
Apr 05, 2013 | Hotpoint Washing Machines
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
I have a hotpoint aquarius WF321 and all the lights on the control panel are constantly flashing which means I can't even turn it off or do anything with the machine. On the odd occasion that it does stop...
i too have the same problem, i am going to buy a new PCB.
which is the electronic circuit board. about 75 quid.
cheaper than a new machine if it works
Dec 04, 2010 | Hotpoint Washing Machines
Noise in drum sound like its gonna blow up
hello, unfortunately the wf321 drum does not split the bearings and drum come as one complete unit and so you need to order a drum unit complete with new bearings and replace the lot
Jun 02, 2010 | Hotpoint Washing Machines
Hotpoint aquarius wf321 when turn on all red light fleshing Problem nothing happenes.
half way through the cycle all the lights start flashing then it makes a loud noise when spinning
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hi i have a wf321 aquarius. When i switch it on
looks like the main pcb is failing you.. checke all connections to be on the safe side( with the power off & plug out of course).
Thanks
Dec 18, 2009 | Hotpoint Washing Machines
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
331 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
