Question about Panasonic SC-AK600 CD Shelf System
Disc Tray will not open . There are no Cd's in the player. It looked like a tray came loose and before I could keep it open it closed. Now the disc tray door is stuck
  • Jodiejtk May 05, 2010
    Thank You!
    I tried searching for a service manual. I will go to the site you gave me and look on there and maybe they have a phone #. My brother is a electrician and does his home theatre. I have seen him take many things apart.
    I will find our about parts manual. Then take it over and put it on his work bench.
    I will write a post explaining what did and did not work. Fill you in on problem.
    Thanks again!
    Jodie
    Scholar:
  • 70 Answers
The unit will need to be dis assembled and repaired by a technician. One of the plastic gears may be broken or misaligned. If you are mechanically inclined you could attempt the repair yourself but be careful not to loose any of the parts.
Posted on May 04, 2010
Testimonial: "I am mechanically inclined. Is there any type of instructions. It looked like the plastic tray came out in the front. ThankYou! Jodie"
  • Dan  Larson
    Dan Larson May 05, 2010
    I would call parts store and ask if they have a service manual for the unit. I see that there is a belt listed in the parts listing so that could be the issue if the tray is loose and can be pulled in and out easily.
    http://www.partstore.com/Model/Matsushit...
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Harman Kardon CDR30 2-Disc CD Recorder both cd
Open the unit, inspect any obstruction, look for the belt that driving the CD tray, if it is loose replace it.
Jun 12, 2010 | Audio Players & Recorders
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
I have a Bose Lifestyle 28. The CD/DVD slot is jammed - it won't open when I push 'open/close'. Now that it's stuck the audio doesn't work. What can I do?
A lot of CD/DVD players have small holes on the front of the disc tray. If yours has this hole get a paper clip. Straighten it out. Gently push the straightened paper clip into the hole. This should manualy release the disc tray. Just pull the tray open and clear what ever is jambing it. These things usually jamb when a disc is not on the tray straight when the tray is closed. If there is no disc look in and see if there is something in there that should not be. I have small children I have removed some very suprising things from our audio and video equipment.
Dec 13, 2009 | Dryers
The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Dec 13, 2009 | Yamaha CDC-745 5-Disc CD Changer
Sony DVD Player keep ejecting CD/DVD tray - not detecting any disc.
if it keeps on opening up and wont close then the tray dectection switch is broken.....you need to get a new player.
or ifs its not reading the disc the laser mech is probably stuffed....time for a new one!
Aug 13, 2009 | Datel Max Media Manager Pro for Sony PSP
Cd tray opening and closing all the time
Dear friend, my sony dvd drive tray opens and closes itself, it is mostly a problem related to hardware. in my case I removed the IDE Data cable connected to the dvd drive and reconnected it again. now my dvd drive works well, I think the problem was the IDE data cable, may be a loose contact.due to this loose cantact,a jung signal goes to the dvd drive, which opens and closes the tray frequently without our knowledge.
Jun 03, 2009 | Technics SL-PD687 5-Disc CD Changer
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Panasonic SC-AK600 CD Shelf System Logo
229 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
