Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
FLYWHEEL REMOVAL - Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
    Guru:
  • 630 Answers
Remove the pull chord assembly, under is the flywheel....remove the 3/4" nut...spray the shaft with WD-40...tap the flywheel gently while lifting the flywheel upwards it should "po" suddenly if its frozen(rusted) onto the shaft get a puller simple to R&R.
Check the "keyway" for wear ..if worn causes the engine to pull your arm out of socket and backfire etc.
Replace the "Key" with a 50 cent part from local hardware store bring in the old one to match up.
Posted on May 13, 2011
  • 623 Answers
You need a flywheel puller tool. You can rent them at most auto parts stores for a few dollars a day. Be advised that flywheels can be very hard to remove, and can come off suddenly and violently when using a puller, keep your face away.
Posted on May 05, 2010
2005 Honda NF 100 Wave flywheel removal
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
2005 Honda NF 100 Wave flywheel removal Google Search
Remove flywheel stator without special tools
http://www.ethicalbox.co/honda_wave_100_service_manual_download.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
May 10, 2014 | 2005 Honda NF 100 Wave
1994 Kawasaki KLE 500 remove the flywheel
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
XT600 Flywheel removal Horizons Unlimited The HUBB
ex500 Flywheel Removal
Kawasaki KLE500 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Apr 07, 2014 | 1994 kawasaki KLE 500
Flywheel removal on yz426 bolt/nut just spins
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Flywheel removal YZ 400 426 450
2002 YZ426 threaded shaft flywheel stator side busted YZ 400 426 450
Yamaha YZ426F Owner Service Manual
OEM parts for Yamaha
Yamaha YZ450F Owner Manual Page 3
Oct 13, 2013 | 2002 Yamaha YZ 426 F
2000 sierra 5 spd removal
Do you mean flywheel removal? A flex plate is the toothed gear that bolts up to a torque converter on a vehicle with an automatic trans. If you mean a flywheel, which is what a clutch bolts up to, then yes it is highly recommended to remove it and have it surfaced when doing a clutch job. And since you are there anyway I would also suggest replacing the rear main seal
Dec 30, 2012 | Cars & Trucks
Fast way to take off flywheel from transmission on1971 chevy c20 350 motor
got to remove the transmission to get to the flywheel
Sep 24, 2012 | Cars & Trucks
2009 Honda CRF100F flywheel removal
Hi, Alex for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
Dirt bike bottom end rebuild flywheel removal
CRF80F CRF100F service manual repair 2004 2013 CRF80 CRF100 Download... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2007 CRF100F Owner Manual
Jun 27, 2012 | 2009 Honda CRF100F
My Jeep cherokee not starting after removal of flywheel. Is there a specific way to install the flywheel?
The teeth on the flywheel need to be close enough for the starter motor to catch them when it engages. If you removed it and now the starter just free-spins when starting then you may have installed the flywheel backwards and the starter motor cannot reach the teeth on the flywheel. If its making a loud grinding or pinging sound you may need to manually turn the engine a bit to align the flywheel.
Aug 21, 2011 | 1995 Jeep Cherokee
How do i remove the flywheel on a huqvarna 272
The fyywheel is on a taper, so there is a service tool to remove it, the early 372XP has a 14mm flywheel securing nut, this flywheel requires service tool 502514902, the crank has a normal wood ruff key, the later 372XP has a 13mm flywheel securing nut, this flywheel has an integral alloy key within the flywheel its self, there is a much simpler knock off service tool for removal 502519401.
Hope this answers your question.
Mar 10, 2011 | Garden
1996 sebring jxi 2.5 ltr sohc 24v v6 4-speed automatic Starter whines but not engaging flywheel. Not turning engine. Not sure about vin ID, but there is an H in the middle of it. Where should I begin?...
If the starter is whinning tht means its operating but not engaging to the flywheel..this could be tht the bendix is faulty...proceed to the starter removal.
Oct 24, 2009 | 1996 Chrysler Sebring
Flywheel removal 1990 Jeep Cherokee standard transmission
I find this article about your question:
- Flywhwwl Mounting Part 1
- Flywhwwl Mounting Part 2
TaperedSplineHubFinal / PDF
So, can review the Jeep Cherokee Repair Manual.
I hope help you with this; good luck (remember rated this help).
Sep 15, 2009 | 1990 Jeep Cherokee Limited
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
330 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
Dan Webster
Dan Webster
John Trevino
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
