Question about Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV
Pc connected to th42phd7 but no picture, input button doesn't
I have connected my pc to panasonic plasma th42phd7 using a 15 VGA pin cable but don't get any picture or sound, and the input button on both the tv or the remote doesn't seem to work, please help
  • 111 Answers
Are you on the right input. To use this set as a monitor you do have to change some settings in the options part of you tv. Also you need to make sure the set is on the right resolution for the PC. check you video options on the PC, and make sure they are the same on the TV set. Also you will not get sound from this type of cable..good luck
Posted on May 04, 2010
What type of cord do I use to connect my PC to HDMI
Hello
There are two types of connections can be done with PC to TV, according to TVs inputs. If TV has a VGA input socket, a VGA to VGA cable is necessary. If the TV has only HDMI input socket, a VGA to HDMI cable is needed.
Feb 13, 2012 | Panasonic TH-50PX77U 50 in. Plasma HDTV
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
I have a HP Pavilion a6838F computer and I want to hook it up to my Hitachi 46" Projection TV (Model# 46GX01B). What cables do I need to do this. I want to watch movies, etc. on the big TV rather than on...
Warren:
Your PC monitor uses the 15 pin VGA connection for the output of your PC.
Does the Hitachi 46" have this type of 15 pin female input connection on it?
The problem is that I don't believe your Projection TV will display the output resolution that your PC outputs.
Many newer LCD or Plasma flat screen TV's have the VGA input feature's as they are made for High resolution inputs such as HDTV '1920 x 1024'
Sorry I just don't beleive that the TV will display the quality image you are so used to on your PC monitor.
Blessings,
A/V Media Guy
Nov 20, 2009 | Audio Players & Recorders
Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Apr 04, 2009 | Panasonic TH-37PE30 37 in. Plasma...
How to conect a pc to a panasonic plasma th50px75u?
Panasonic didn't make it a simple matter to connect a computer to this TV since they didn't include a VGA input connector. You can still do it, but it will require some adapters or changes to your PC.
If you're using a laptop, you have two options. If the laptop offers an s-video output, you can use a suitable cable from there to one of the set's s-video inputs. If there's no s-video output, the other option is to purchase a VGA-to-component breakout cable, available at a number of online vendors (search with Google). This cable has the VGA connector to the computer on one end, and 3 RCA plugs at the other end. You would use this cable into one of the set's component video inputs.
With a desktop PC, you can still use one of those two options. In addition, there may be a DVI video output connector available as well. This is not common on computers with integrated video, but is frequently found on many newer expansion video cards. If your computer has this connector (or you install a new video card with one), you can use a DVI-to-HDMI adapter and connect an HDMI cable to one of the set's HDMI inputs. Many video cards with DVI outputs include one of these adapters already.
So while it's not going to be simple, it's certainly possible to connect your PC to this TV.
Feb 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Mar 08, 2008 | Televison & Video
How to connect samsung plasma tv to a toshiba laptop?
to get high definition you will need to use either the vga or dvi output from your notebook and connect to the DVI input on the tv, vga connection on the tv will only give 480i whereas dvi will give upto 720i
Nov 04, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV Logo
199 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
