Question about GE JKP20 Electric Single Oven
GE profile 27" drop-in range JMP31WCWW Why does bake coil not work when broil coil does?
  • 523 Answers
Two diff relays for them replace relay board
Posted on May 06, 2010
Oven gives err message when set above 275 degrees
Your range has been reset to celsius from fahrenheit. It must be reset to fahrenheit.
Press bake and broil pads simultaneous for approximately 3 to 4 seconds.
When SF comes on, press the broil pad.
You should see the Letter C.
Press again and the letter F will come on.
Press start.
Your range shouldproperly set the temprature now!
May 03, 2012 | GE Profile JTP56 Electric Double Oven
The igniter was bad i replaced it with a new one (seemed simple enough) but when i put it on broil or bake the igniter doesn't turn red, is there something i'm not doing?
The igniter is in 'series' with the gas coil that operates the gas valve. The gas coil is probably bad. You can replace the coil not the whole valve. Go to repair clinic.com and put in the model number and they will have it.
Nov 06, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
GE oven bake igniter is bad ?
Yes, it should work fine to swap them. (fortunately the bake and broil igniters are often the same part number on GE gas ranges, as as opposed to many other brands) Of course now you broil will not work, but you should be able to get your oven going again.
Jul 15, 2009 | Ovens
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
JTP18WD01WW no broli, no bake panel works
my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
GE JKP20 Electric Single Oven Logo
59 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
