Question about Samsung RS2556 Side by Side Refrigerator
Samsung rb1855sw My fridge has been freezing vegetables on the bottom. I cleaned condenser coil and noticed that the defrost water tray was dry looks like it has been for a while. I believe that I have a possible defrost issue, as I found ice on the back of the fridge. I looked for the defrost timer to manually test, but I can't find it. How can I force into defrost to confirm its operation? Don Ashby
  • Anonymous May 26, 2008
    how shall we clean defroesting water
    President:
  • 1,197 Answers
We ll see how u need to check the defrost timer....
Before testing the defrost timer, unplug the freezer to avoid an electrical shock hazard.
A mechanical defrost timer controls the defrost cycle of the appliance. In older models, the timer runs continuously and roughly every six hours, shuts off power to the cooling system and sends power to the defrost heater. In newer models the timer advances only when the compressor or defrost cycle is running - an improvement for efficiency. As the timer advances, power to the heating element shuts off and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill of the freezer. It may also be found behind a cover plate inside the freezer, in the temperature control console, or behind the freezer near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Test the timer for continuity using a multitester. Set the multitester to the ohms setting X1. The timer has four terminals. Locate the common terminal, it should be labeled "3" or "C". If the terminals are not labeled, determine which terminal coincides with the common wire in the connector plug; it is usually the white wire.
Once you have located the common terminal, touch one probe to it. Touch the other probe to each of the three remaining terminals. The multitester should display a reading of zero or near to zero ohms (which indicates continuity) for one pair of the terminals and possibly two pairs. The third pair of terminals should show no continuity (infinity).
Locate the timer switch and turn it clockwise until you hear it click. Now retest the timer as you did above. One pair of terminals should indicate continuity (possibly two pairs). At least one pair should give a reading of infinity. Note however, one of the pairs that showed continuity in the first test should now read infinity and one pair that read infinity should now show continuity. If the defrost timer does not pass these tests, it is likely that it should be replaced.
Before testing the defrost heater, again make sure u unplug the freezer to avoid an electrical shock hazard. The defrost heater is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear or bottom inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. There are three primary types of defrost heater elements; exposed metal rod, metal rod covered with aluminum tape or a wire coil inside a glass tube. All three elements are tested in the same way. The heater is connected by two wires.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced. Test the heating element for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading somewhere between zero and infinity. If the reading is not between those two extremes the heating element should be replaced.
this is how u check the thermostat..... again Before testing the defrost thermostat, unplug the refrigerator to avoid an electrical shock hazard. Some defrost systems use a thermostat (a bi-metal switch) to prevent the defrost heater from overheating. The switch is normally closed. During a defrost cycle, the defrost heater causes the metal alloy in the switch to warm and as it does it curls back and breaks the circuit. As the metal cools, it makes a circuit again and the defrost heater starts heating again (as long as the defrost timer is in the defrost cycle). A defective thermostat can prevent the defrost heater from coming on or allow it to overheat which could result in heat damage or fire. The panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. On some older top freezers it is necessary to remove the plastic molding to access the freezer floor. Removal of that molding can be tricky -never force it. If you decide to remove it, you do so at your own risk - it is prone to breaking. Try warming it first with a warm, wet towel. The thermostat is connected by two wires. The wires are connected with slip on connectors or a wiring harness. Firmly pull the connectors or harness off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced. Test the thermostat for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of zero when the thermostat is cold and a reading of infinity when it is warm (40 to 90 degrees F depending on the model). If the thermostat does not pass this test it should be replaced. with regard to the parts incase u need a replacement..... check out the below link.... http://www.repairclinic.com/GE-Freezer-Parts?s=b3a3c221
Posted on Sep 01, 2010
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
My Samsung SRL550DW keeps cutting out. If you turn the power off it restarts and works fine and then cuts out again after a few hours. Is this a main PCB problem. Prior to this happening the door chim
I have had the exact same issue and its not a samsung issue but any modern fridge with a defrost system in the freezer (fridge doesn't generally frost up as its not run at freezing temperatures.
You need to check a few things:
1. Clear the freezer draws out and clear any ice build up.
2. Be careful and unclip the first white plastic vent panel (hint: pull from the middle an inch or two then push the sides in so the tabs are pulled towards the middle and the panel pops out)
3. Unscrew and unclip the 2nd panel (holds the circulation fan) to view the freezer coils - you will need to unclip the power for the fan and the heating coil for the drip tray under the freezing coils.
4. This is where the issue usually is:
If the tray is full of ice then do the following. If not and you can poor water through the drain hole on the bottom, then the issue is a dead sensor or control board - seek professional advice or if your game, there are swap out kits you can buy.
So the drip tray is full of ice ? Unscrew the freezer coils from the back wall but DO NOT touch it any further in case you damage it. There should be some silver tape tape that holds the tray in place - remove it and then gently lift the coils up to allow the tray out. If its too full of ice, use a hair dryer or warm water to de-ice. Once the tray is out, defrost it completely and dry it - be careful not to damage the heating wires under the tray as this is used to deice it during a normal defrost cycle. Clear any remaining ice on the coils or along the back wall - Dry it well.
Usually the cause for the drip tray to freeze up is a blockage in the drain pipe that empties into the back of the fridge. Unscrew the back panel and you will see 2 soft plastic pipes drain water into a water tray. pull both off and clean/inspect. You will notice they pinch in the middle to stop air getting back in, but allows water to drip out. If they are blocked, they will back fill the internal drains and freeze, thus fooling the fridge into thinking it hasn't defrosted yet and not turning the compressor back on. (Since this ice is hidden at the back, it is the last to melt thus the freezer gets warmer waiting for the insulated ice near the drain to melt.
When I did my freezer, the water is dripping out slowly (it was cold) but once I removed the pipe, it emptied properly. inspection of the pipe showed dirt/insect blocking the pinched section of the pipe.
Reassemble the pieces in reverse order, ensuring the water was been dried with a cloth. My fridge/freezer hasn't skipped a beat since.
May 07, 2012 | Refrigerators
Getting water under the vegetable trays sometimes ice will form.
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 11, 2011 | Samsung RB217ABWP (21 cu ft) Bottom...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Water running out bottom of freezer
That's exactly what it it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 27, 2009 | Kenmore 53642 / 53644 Side by Side...
Water leaking onto floor from refrigerator/freezer
The defrost drain is stopped up. Without taking anything apart, the easiest way to clear the drain is to blow compressed air through the drain tube which is at the back of the Fridge. You'll see it..... it drains water into the drip pan. Hope this helps !
Oct 09, 2017 | Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
409 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
