Question about Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor
Dell 2208WFP won't power up. No LED's, no clicking, nothing at all. Power button click seems OK.
  • 4 more comments
  • fy51 May 05, 2010
    First of all, thanks fore the quick response. Looking closer at the model number, mine is a 2008WFPf, and the board is just a bit different. Here is a picture of my board... http://picasaweb.google.com/bwthor/Monit...
  • fy51 May 05, 2010
    OK, I checked the fuse, and there is continuity across the terminals. On the big cap, you say 160vac, do you mean DC? I checked AC first, but it pegged the meter. Set on DC it is at 160.
  • fy51 May 05, 2010
    Yeah, both legs of the axial fuse are at 5vdc. I really appreciate your help up to this point, to be honest I was surprised to get a response at all!
  • fy51 May 06, 2010
    I uploaded the pics tohttp://picasaweb.google.com/bwthor/Monit... I checked the voltage coming from the red and black wire connector. From the red wire, the black wires test 0 - 0 - 5.4 - 5.4 - 5.4 - 3.7 - 3.7 - 5.4 - 0
  • fy51 May 06, 2010
    Nothing at all. Acts like it is unplugged from the wall. I also tested the little power switch to make sure it was making contact.
  • fy51 May 06, 2010
    Sorry, I'm not quite sure which contacts you would like me to test. I've updated a picture in the gallery to help me clarify which pins. Could you take a look please. Thanks again.
  • 11,361 Answers
You need to open it up and inspect the main fuse (red round part by the AC inlet), DC filter caps (look for bad caps with leaking or bulging tops).
Board: http://www.lcdrepair.us/E2208WFPt-inverter-power.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 05, 2010
  • 4 more comments
  • Bud Martin
    Bud Martin May 05, 2010
    OK, I look at the picture, the fuse is the round black component near the AC cord inlet, it is labeled with T3.15A/250V.
    You should check (two pins of the cap) to see if you have about 160vac on the big cap (the one that lay down side way with two pins showing). You must be real careful here! Lethal voltage, you should be working on this board when it is plugged into GFCI OUTLET ONLY!
  • Bud Martin
    OK, 160VDC is good, there is another small fuse close to the white connector with one red wire and black wires that is also need to be Ohm out, it is an axial fuse, T5A 125V, if you check with DC volt meter beween ground (chassis) and either one of the fuse leg, you should have 5vdc. It is a little difficult at this point for nto having the board infront of me to do deep troubleshooting.
  • Bud Martin
    Bud Martin May 06, 2010
    Well that means the main power supply is working. So right now do you get any indicator light at all? Since the 5vdc is used for the logic board which is upplied by the red and black wire connector. If the 5v is feeding the logic board but there is no response from power switch, then we can assume that the problem is in the logic board, but I need to know the condition of the power indicator first to go to the next step since 5v will be stepped down to 1.8~2.2v and 3.3 by the regulator on the logic board. I may need to see the picture of the logic board next.
  • Bud Martin
    So there is no indicator light comes on when power switch is activated? The sreen did not flash on for a seconds?
  • Bud Martin
    Please measure the dc voltage on the four pin of the power switch, before pressing and press and hold. You should have around 0v to 3.3~5v reading during press/not press.If do see it change state then it will tough to go from there since you may have microcontroller problem or the EPROM is scrambled.
  • Bud Martin
    I am talking about the pin on the power switch itself, there should be four pins per switch. The connector you show is set up as a matrix for scanning for the signal being sent by the switches which is then decoded by the microcontroller.
Were can i buy the same caps as he needed i dont know were to get them
Posted on Mar 17, 2011
Power LED gives a single red flash
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Feb 14, 2013 | Panasonic BL-C20 Network Camera
Dell 2208WFPt no power - nothing.
Check the cord at the wall and the back of the monitor. If you can use a known-good cord, and still nothing, then your best bet is replacing the monitor completely.
Dec 12, 2012 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I put my Dell Vostro 1000 laptop on charge and click the power button for it to turn on and nothing happens. When I put the AC adapter on charge the batter LED flashes on and then off. Please may you help...
Hi there its sound like SMPS ( power supply Unit ) problem. Some how he not able to accept the power or hold the power and then forward it. It Is complete hardware problem.
Jan 17, 2011 | Dell Vostro 1000 Laptop
When I press the power button on my studio 1555 nothing happens. I have tried with and without the battery plugged in. I am so confused as to why it isn't turning on. over the past week it has been a bit...
It could be a mechanical failure of the button in the hinge assembly.
It could also be that the AC adapter wasn't working and the system was powering off battery till batter died.
Are there any power indications on the system? (Battery LED with AC Adapter connected?) If there are power indications then the power button seems to be the possible fault.
If no power indications, try a different AC adapter
Sep 05, 2010 | Dell Computers & Internet
DELL 2208WFP LCD-Comes on normally, but almost immediately goes dark You can see something on the screen if you look closely. Turn it off and back on you see it then dark. any help?
I believe the power led button is still on while the screen goes dark, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes dark after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes dark.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
My monitor states its in power save mode.when i press any key,nothing seems to happen.
To bring the computer out of the power save mode press the "Windows" key once and release, wait one second, then press enter. The system should come out of power save mode. The Windows key is the key with the Microsoft Windows Symbol on it. Another solution would be to disable power management.
To disable power management, right click on the desktop, click on properties, screen saver, then Energy Savings Settings button.
Change all the settings to "Never", then click on "apply" and "ok". Power management has been disabled.
Apr 29, 2010 | Dell E173FP 17" LCD Monitor
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Dell 2208wfp usb port
your ports have lost their driver .
go to start
right click on my computer
click on properties
click on hardware tab
click on device manager
scroll until you find port tab double click on port tab
right click on each port one by one and click on update driver .
this normally should do it .
If it does not , go to Dell support :
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
and download new drivers for your port
Oct 24, 2009 | Dell Computers & Internet
Dell dimension 5100 - no power
It seems that your SMPS power supply may be having some fault...try to replace it...
Dec 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor Logo
1,065 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
