Question about Elna Xplore 8600 Computerized Sewing Machine
Elna 8600 - Carriage will not move backward or forward only left and right when I try to embroider
    New Friend:
  • 194 Answers
This could be a loose connection on the circuit board or it may be a bad board, either way it should go to a tech for repair.
Posted on May 07, 2010
My elna club 4D seems to be working backwards. if i turn the knob backwards (the arrow shows i must turn it forwards) it sews, but if i turn the knob forwards (in the right direction) the threads don't...
What were you doing immediately before this started? Buttonholes? I bought an Elna SU in 1973, still going strong now. Sometimes after doing buttonholes it did weird things - fortunately I had two friends with identical machines to help me. I hadn't put all the controls back properly after doing no turn buttonholes. I just wonder if you'd got the same problem?
Nov 02, 2013 | Sewing Machines
How to embroider with elna su electronic
There are a couple of Elna SU models, the Star Series SU is white with a blue top panel. Or the air electronic SU is a white machine and a dozen years newer (80's). Both have a disc elnagraph reader in a flap on top of the machine and sew a range of stitches involving either side to side stitch formation or side to side and forwards and backwards, albiet revolutionary when new but not what modern computerised embroidery machines can produce now. To use, you set stitch width and length dials to zero, then insert the black disc into the elnagraph ensuring you line up the disc with a little finger underneath. There should be a red marking on the disc and the shaft to assist with this. Press down until the disc clicks into place. Now turn stitch length to S for supermatic and width to 4 and sew. You can vary the stitch width to adjust stitch and the AE also has a little dial that elongates or closes up the stitch. Try machine embroidery thread for a silky stitch especially with satin stitch where the thread is close together. Also wing needles can be interesting when using the turkish hem stitch disc.
Dec 29, 2012 | Elna Sewing Machines
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
Apr 10, 2011 | Elna Sewing Machines
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Cloth will not move forward
Cogs are feed dogs.
Check your manual to see if there is a pressure adjustment for the presser foot.
This may be a nob on top of the machine directly over the presser foot.
Turning the adjustment left/less or right/more pressure.
Also, refer to the manual for cleaning the bobbin and feed dog area as lint may be causing a bit of the problem.
May 01, 2010 | Elna 2005 Mechanical Sewing Machine
The carriage on my Janome 350E will only move left or right - NO forward or backward movement.
When my janome 350e did this I had to take it in to be calibrated and one month later it did it again and I had to take it back it has not given me any problems since but it would be nice to know how to do this myself it only took 5 minutes for this and takes me 3 hours there and 3 hours back. Hope this helps.
brenbb@skywayusa.net
Nov 20, 2009 | Janome Sewing Machines
Carriage on deco 330
I had the same problem with my bernina deco 500. Fortunately I could solve the problem, I have posted my solution please read it, it might help.
good luck.
Amany
Jul 04, 2009 | Bernina Bernette Deco 600
I have an elna 9000 and im finding it very hard to embroider letters... they seem to start overlapping after a few goes? is there anything you could suggest please? thank you
Hi....there is a dial at the bottom right of the machine to shorten or lengthen stitches.....you need to play around with this until you find the right length for embroidery work.....( I find the longer length is necessary to stop overlapping)......also alter the feed setting ( behind door top left hand side) according to your fabric....hope this helps
Apr 28, 2008 | Elna 1010
Elna Xplore 8600 Computerized Sewing Machine Logo
151 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
