Question about Xerox Phaser 8560DN Laser Printer
My Xerox Phaser 8560 gives a printer error 04,021.42:40969 and then prints sheets and sheets of xerox terms
  • redwoodcp May 05, 2010
    Thanks-- just a question... this machine has been printing "garble" from the very beginning. I'd ask it to print, and it would print garble-- but when I pressed cancel and and asked it to print again it would do it. Lately, it just continues to print garble unless I unplug it and it seems to clear for one more print job. The tech where I bought it said it was an issue with it being hooked up USB rather than ethernet. Is there any truth to that?
    Genius:
  • 1,043 Answers
The first thing you can do is to download a copy of the Service Manual for your printer from the following website:
https://www.office.xerox.com/partners/products/Phaser8500/Phaser8500Series.html
If you take a look at page 3-10, it gives you a breakdown of what your error code signifies. The code indicates a fault with the process control system (note that the 40969 number indicates how many pages have been printed on your current print engine). This further alerts that there is a temperature issue causing a problem with the drum..
The troubleshooting steps are outlined directly below the code breakdown. Essentially you want to make sure that the room your printer is located in is within the correct operating temperature guidelines which can be found on page 1-12 (50-90 F operating, 68-77 best temperature for preventing paper jams). If the room temperature is okay then you need to run the Monitor Heaters Test with all heaters turned on. Yo be able to run this test you first have to get into the Hidden Menu (manual describes how on page 4-2), then scroll down to the Enter Diagnostics choice and press the OK button. Page 4-4 describes how to get to the Service Diagnostics menu either with or without a reboot of the printer. Page 4-6 and forward describe the menu in detail. You'll be looking for the Exercise the Heaters menu described on 4-8. If the heaters are operating within their specified tolerances then you will have to replace the Electronics Module. If one or more of them are not operating correctly you will have to inspect the harnesses to each of the heaters. If any of them are damaged they will have to be replaced.
Those are the steps you will have to follow. If you are not comfortable working with the printer at this level you will at least know what the problem is and what may have to be done to resolve the issue. If you have a service contract on the printer you can have it repaired per the conditions of your service contract. If you don't have a contract you can ask the repair tech to give you a price on what the repair will cost depending on how far down the steps he will have to go to resolve the issue. Good luck, and I hope it is a quick and cheap issue to resolve for you.
Posted on May 04, 2010
  • bvanjoff May 05, 2010
    There could be a problem either with the USB port of the computer it was connected to, or with the USB port of the printer itself. This would include the electronics of those ports. The tech should have mentioned that you coud try, if possible, to reload that part of the printers communication software that controlled the USB port. An easy way to try and narrow down the issue would be to connect another peripheral to the USB port of the controlling computer to see if it would function correctly. If it did, then there is probably an issue with either the printers software or the USB port itself. Take a look in the service manual that you downloaded and do a text search for the word USB. There is probably a few items in the diagnostic menu that would allow you to run a basic test on the port. You could also check with the Xerox website to see if there were any updates for your printer.
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Feb 26, 2015 | Xerox Phaser 8560/YN Printer
ERROR MESSAGE PHASER 8560 09,006.41:150694
9,006.41: The magenta ink melt heater is On, but ink is not dripping.
Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink cubes.
Apr 07, 2014 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Feb 07, 2014 | Xerox Phaser 8500/DN Printer
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
May 22, 2011 | Xerox Phaser 8500/DN Printer
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8560DN Laser Printer Logo
134 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
