Question about Canon imageRUNNER C3200 Color Printer
Error Code Does anyone know what the meaning of error code E000584-0002 for Canon imageRunner C3200 Color Copier ?
  • helpdesk422 Jun 20, 2008
    I have that error too. I was wondering if it had to do with overheating? We get the error and then copier shuts down
  • mbx62org Feb 24, 2009
    I have the same problem. However, if you turn the machine (main switch power) off and on, and reboot the server, it should solve th eproblem. If it still has problem, then it's got to be something to do with finisher (if you have finersher attached).
  • 3 Answers
Check the registration motor and right door or door switch
Posted on Dec 12, 2008
Called local service technician.
Posted on Mar 27, 2008
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
Error code canon copier
this error code it shows that there some particle onside the machine you need to clean and to change cyna developer
Feb 22, 2010 | Canon imageRUNNER C3200 Copier
Problem on Canon imageRUNNER C3200 Copier Error Code We have an error code of e000020-04b0
replace black drum it is reaching the end of its life also make sure your machine has the latest software version as drums will last longer if it has have seen drums reach 700-800%
Nov 04, 2009 | Canon imageRUNNER C3200 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Error Code E00002-01c0
you probably mean E000020-01c0 bad yellow drum codes in order 01Y 02C 03M 04B
Apr 10, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Error code on Canon ImageRunner C3200
check the yellow drum unit, laser shutter or the plastic actuator on the right side of the front door, also check the pattern reading unit for dirt
Feb 19, 2009 | Canon imageRUNNER C3200 Copier
Error Code
The error code is saying you have a fuser fault
Try resetting the machine
get into service mode
then COPIER
then FUNCTION
then CLEAR
then ERROR
then OK at the bottom right hand corner
if you dont know how to get into service mode
call me 00447764303923.
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Color Printer Logo
629 people viewed this question
old marine
old marine
