Question about Troy-Bilt Pony Garden Tiller
What oil goes in the gearbox behind the motor , I have a junior
It's the box between the motor and the tines
    President:
  • 1,902 Answers
Any type of gear oil will work for this. I know some gardners that use tranny fluid for heat
Posted on May 04, 2010
Testimonial: "thanks so much. when I drained it, it looked like motor oil that was in way too long. thanks again"
The motor runs fine, it stopped tilling, and the belts do engage properly. What happened
Randy, The gear in the gear box may have sheared a key, or damaged gear. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tiller Gearbox Trouble
Murray Ultra Tiller Tines Won Keep Spinning
Update Craftsman rear tine tiller repair stuck gears
Apr 23, 2016 | Garden
What weight oil goes into the gear box? whats the proper weight oil for the motor?
30 weigh oiltdetergent (if available,if not regular 30 weight oil will perform also), as for the gearbox.transaxle for the tines use 80-90 weight gear lube
Apr 16, 2011 | Troy-Bilt Pony Garden Tiller
Troy bult junior has new tines , runs to fast...
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
May 19, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a MTD yard machine rear tine tiller. Goes forward and reverse but tines wont rotate. How do I fix?
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Apr 30, 2010 | Mtd Products Yard Machines 158CC Tiller
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tines wont turn when in ground, but they will before they go into dirt
If it's a belt drive motor, you have either worn a bad spot on the belt or sheared a key off a shaft. If its a top motor bottom drive tiller, it will be the clutch where the shaft of the motor goes into the gearbox of the tiller. Let me know if this helps :)
May 14, 2009 | Mtd Garden
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mitsubishi Pajero Junior Automatic Gearbox Problem
I have a pajero junior 1997 4A31, I am having problems, with my gear, when take off in D the car is slow, and up hill no power in 2nd & D, in Load ok. Plse advise. Thank you.
Apr 01, 2009 | 1990 Mitsubishi Minivan
How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Mar 19, 2009 | Troy-Bilt Garden
Troy-Bilt Pony Garden Tiller Logo
384 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
