Question about Frigidaire Electric Dryer
I need a diagram of how the belt goes on my Frigidaire dryer?
My dryer is about 101/2 years old, its been great but started to squeek, as its going around, I took it apart to see if the belt was getting rotten,
seem to be ok. My problem is, I put part of it together, to check and see if i could find the problem, and when i turned it on, there was a spark and a slight flame, I blew it out, all seems fine but when i did put it all back together it now wont heat. Could I have blown the heating element or something else. I can usually take apart things and put them back together properly, but I'm pretty sure I did'nt this time.
Help!
Caprice
  • t_n_c83 May 04, 2010
    Model # is FDE336RES2
    Serial #is XD92985424
    thank your Mrs. Giardina
  • t_n_c83 May 07, 2010
    DID YOU GET MY MODEL#? AND NO THE ELEMENT WAS'NT ON FIRE, IT WAS SOME LINT ON THE BOTTOM OF THE DRYER, I HAD PULLED MOST OF IT OUT, BUT THE SPARK WAS ON THE SIDE, THANKS CAPRICE
  • 15,935 Answers
What is the model #??
Thanks!
Posted on May 04, 2010
  • blueextc3221
    blueextc3221 May 05, 2010
    CLICK HERE to see the heating element... is this what was on fire??
  • blueextc3221
    blueextc3221 May 07, 2010
    The spark came from the side of what? The element?
    I guess we're not on the same wavelength here.
    Anyway - the dryer now runs properly - but will not heat?
How do I fix the squeaking when the dryer starts up in a fridiadare gallery dryer with model number 341as1 and serial number x021308125
It quits down after it runs awhile?
Your Belt and Rollers are getting old. Live with the short term Squeek or replace the Belt and Rollers and idler
Dec 15, 2013 | Frigidaire GLER341A Electric Dryer
Frigidaire electric dryer. 1.5 years old, stopped turning and only hums when button is pushed
Hello
Is it a pleasant sounding hum, like the sound of a motor running? If so , probably your belt broke.If that hum goes on and on for several minutes, it's definitely belt. Bad motor or start relay, would cut out quickly. Either way ,youv'e got to pull out machine and pull off back to inspect.
Aug 18, 2011 | Frigidaire GLEQ642A Electric Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
My series 80 dryer squeaks
do not lubricate anything in a dryer you will damage .locate the the squeek if it is coming from the rear of the unit most likly need to replace the drum support or wheels if its intermittant and has a squeek squeeek noise that either gets worse or goes away when the dryer heats up the tensioner pully or the moter berrings are bad
Aug 10, 2009 | Dryers
Frigidaire FDE336RES2
open the motor cover hole on the back of the dryer and right above the hole to the right side is a yellow plastic gear like mounted to the back plate of the dryer
Nov 02, 2008 | Frigidaire Dryers
Stacked washer dryer
It sounds like the belt or a pulley!
Anything more and it's not worth fixing if it's 10 years old .
Then better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire Front Load Dryer
Reach inside the drum and feel the drum inserts to see if one of those has come loose. Sometimes you can have one of those screws back out and hit something on the inside. Could also be a bent drum (doubtful unless its been overloaded or abused real bad) a front slide is bad (would probably cause squeeking or grinding noise) or rear bering (also should squeek or grind). Good Luck!!! Jim
Sep 07, 2007 | Dryers
Frigidaire  Electric Dryer Logo
50 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
