Question about Stanley Air Tools & Compressors
Bostitch 18 gauge nailer missing rubber no mar tip.
Bostitch 18 gauge nailer missing rubber tip, where to purchase a few?
contact foot, no mar
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
SOURCE: We have a Bostitch nailer that leak out of the end
you need oil....put oil in the mail fitting, just a little and it will go away. your o rings are dry and wont create a seal.
Posted on Mar 09, 2010
  • 100 Answers
SOURCE: how do I load nails into Bostitch SB-1664FN 16
from the side, not in the back or front.
Posted on Apr 19, 2010
  • 4234 Answers
SOURCE: The driver on my Bostitch nail gun won't retract
This is usually caused by either a lack of lubrication or a defect in one of the seals. If hte nailgun has been uised a lot, purchase an O-Ring kit and replace all of the O-rings. That should resolve the problem. I believe that these kits are available for around $20-$30.
Dan
Posted on Apr 27, 2010
  • 21 Answers
SOURCE: I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Posted on Jun 13, 2010
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Nailer drives nails too deep
n80 coil nailer is a very powerful nailer used for hard wood. If the driver is setting nails too deep, adjust safety foot to the lowest level. Install safety foot no-mar boot to lift the gun even higher. If still too deep, most likely the lower bumper inside the gun is worn-out or cracked. Easy test. Remove nails and connect air supply. With trigger depressed, push and hold the gun against work (I use an old rubber hose tightly coiled up). This will fire the gun but keep the driver down allowing you to examine the tip of the driver. The driver should extend out past the nose less than quarter inch. If the driver is extending too far, most likely bumper is worn out. If a large quantity of air is leaking out the nose of gun during the test, indication that lower bumper is cracked. Good luck.
Apr 06, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I just bought the Bostitch SB1850BN 18 gauge brad nailer with the Bostitch CAP2000P-OF air compressor. When I hook the hose up and start the compressor, I cannot get the nailer to fire a nail. Only air...
Check the position of the switches and selectors. It sounds like you are in between settings. Also, put in a few drops of oil, and try your gun out on scrap wood, so oil doesn't come out on your good work.
--W/D--
Jan 21, 2011 | Stanley Bostitch SB1850BN 18Gauge Brad...
When I pull trigger air is escaping around the trigger and nailer will not engage
you need a new trigger valve assembly, there is an o ring that has split. Contact Bostitch for a replacement part.
Oct 08, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
What is the right psi for an 18 guage bostitch brad nailer
usually about 90PSI will work well. anything more and you might have problems. It generally states this on the magazine.
Jul 15, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have a Bostitich brad nailer model BT200 it's 7 years old
The nailer needs some lubrication. The rubber gaskets are not riding in the shafts correctly. I would have this rebuilt and lubricated. It should be used one every few months to spread the oil around and keep the rubber parts oiled. Check with your local lumber yard. If they deal with Bostitch, you may be able to get a "rebuild" for the purchase of a box of nails. I was able to get a couple of guns overhauled this way during the local "Bostitch days".
Dan
Dec 28, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
18 ga. Bostitch nailer that has a small brad jammed in it.
check your hex wrenches they could be standard when they need to be metric.
Sep 23, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Air Tools & Compressors Logo
241 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
