Question about Alpine CDA-9833 CD Player
Volume won"t pass 20 cut's off dack
I install a alpind cd 9833 and when I turn the volume control pass over 20 the deck will shut off need help.
The Alpine cda983 does this is because one of your speaker's in your car has something awrong with it.Diconnect each one, each time turn up the volume for each speaker. This fixed the problem for me.
Posted on May 23, 2008
Get your battery checked.
Posted on May 11, 2008
  • 113 Answers
The speakers either cannot handle the poew and shut off to protect the radio- or the wiring for the speakers are not insulated well or your groung is not good
Posted on Mar 27, 2008
When raising volume deck cuts-off
Sounds like an overheating issue. Most car receivers have heat sinks at the rear to dissipate heat, but if there is little or no rear clearance for the unit the heat may build up and the unit goes into a self protection mode and shuts down.
Sep 01, 2015 | Car Audio & Video
Aux wont work
check the devices volume level. I had the same problem with my phone. Every time i plugged it in the phone volume level would go down to about half way. hope this helps
Apr 20, 2014 | Alpine CDA-9833 CD Player
Deck shuts off, when loud, while idling or at stop lights.
You are working your deck to hard, it is overheating and shutting down (protection mode) You like it loud, you will need a 4 channel amp. Also check the ground on your deck to ensure it has a nice connection.
Jun 02, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Losing power
mine does this too, I have the deck on my boat and on land the deck cuts out when a bass line hits or loud music comes in, cuts out at about 20 on the volume level, however, when on the water and the motor is running, my voltage is up to 14 vdc or so.. At this point, I can crank the deck up to 30-37, and it will scream , doesnt cut out or lose power just rocks. I have heard that kenwood decks are competition stereos and require 14-16vdc, but I have never found any proof of this. One thing you can do is order a battery from that runs higher than 12vdc. But then again im just speculating
Mar 05, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
Finding how to set the treble and bass
Under the silver volume knob is a thin silver bar. Push it and the menu will pop up on the screen. Continue to push this bar to scroll through the different options. It controls bass, treble, balance, fade, sub volume etc. Good luck, hope this helped.
Dec 19, 2008 | Alpine CDA-9833 CD Player
Mitsubishi magna sterio wires
first of all you should always use a wire harness when installing a unit into a vehicle you should never cut the factory harness but guess you already did so here is the wire diagram for your car hope this helps
Sep 24, 2008 | 2002 Mitsubishi Lancer
Swapped out cd players now getting high pass through subs
this is very easy...just unplug the rca cables out of the back of the deck, and plug them into the "subwoofer" output. On some alpine decks this is on a "pigtail" wire that extends from the deck. Once this is connected to the right output, you can control the subwoofer level from the volume knob by pressing it inwards.
Also.... your amplifier should have a low pass filter, it should be on a switch marked "LPF". Make sure this is switched on.
Feb 25, 2008 | Car Audio & Video
Head Unit Shuts Off At a Certain Volume
check your ground, it could be that your antenna is the only source of ground, in which case the deck does not have enough power to stay on when it draws too much power. I've seen exactly what you are saying many many times. Ground it really reallly good.
May 10, 2007 | Alpine CDA-9853 CD Player
Need help unlocking code on kdc-x789
Make sure you're entering the code correctly; use the control knob's 4-way controls to select the numbers, and when you're done press and hold the control knob for at least 3 seconds.
Mar 06, 2007 | Kenwood Excelon KDC-X789 CD Player
CDA - 9833 AI-Net issue
If the radio was still plugged in when you cut it (such a BAAAADDD idea....) it likely shorted the data pins to the power pins which fried the AI net processor. There is no fix for that. It's toast.
Aug 20, 2006 | Alpine CDA-9833 CD Player
Alpine CDA-9833 CD Player Logo
189 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
