Question about Marantz CDR420 CD Recorder
Marantz cdr420 recorded media stored on harddrive.played back all fine unplugged now it says no valid files when i try to burn the disc but the drive reads full.
If you are attempting to burn mp3 files as an audio CD, then that's the problem. You cannot burn audio CDs from MP3 files. You have to burn MP3 files as a data CD and not as an audio CD. See excerpt taken from page 33 in the CDR420 user guide. "Prepares CDs that can be played on standard CD players. Compact Disc Digital Audio (CDDA) uses uncompressed PCM, .wav files. The CDR420 does not convert MP3 files to PCM so MP3 files are ignored if you choose AUDIO as the CD TYPE"
Posted on Sep 06, 2010
How can I get my CDR420 to record again?
did you check the belts inside the mechanisum.?
Aug 20, 2014 | Marantz CDR420 CD Recorder
Will not burn a CD
Have you checked which CDR media the device can use.
This may be as simple as using a CD-R rather than a CD+R or vice versa,
Also check if you may be burning to a CDRW or CDR.
Apr 03, 2014 | Marantz CDR420 CD Recorder
'Writing Error' during last stages of burning a cd.
could be bad cd's ,but id say your recorder is going bad. you can try cd rw disks they work better in this case. then use a pc to copy to regular cd then reuse the cd rw disk again.
Sep 26, 2013 | Marantz CDR420 CD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Can i transfer information from the recorder to my computer? marantz model cdr420.
Depends on your PC and its audio capabilities.
http://www.zzounds.com/item--MARCDR420
It has analog line I/O, and SPDIF digital I/O, and USB 2.0, allowing you to connect the CDR420 to virtually anything in the world.
Feb 10, 2011 | Marantz CDR420 CD Recorder
No Valid Tracks or No Song Select
Feb 14, 2010 | Marantz CDR420 CD Recorder
Need to download the recorded media to a computer.. any special step because the hd on the cdr420 isnt; pullin up??? i dont have the manual and cant find it...manual would be helpful to have too...
Hi, i have located the manual for this device. you can access it and, print it out as well if you choose. the link to your manual is below.
CLICK HERE FOR THE CDR420 USER MANUAL
Please rate and god bless:)
Apr 17, 2009 | Marantz CDR420 CD Recorder
Marantz cdr300
try turing off opc in menu see if that helps use hi end meadia only memerex i like
Jan 18, 2008 | Marantz CDR420 CD Recorder
Frozen CDR420
if you already recorded the voices, no ploblem, unplug the power supply will not destroy the recording. and start playbak again.
Nov 05, 2007 | Marantz CDR420 CD Recorder
Marantz CDR420
Simply switch the analog to digital button on the front to analog, turn off the machine and turn it back on.
Oct 09, 2007 | Marantz CDR420 CD Recorder
Marantz CDR420 CD Recorder Logo
443 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
