Question about Meade ETX-125EC (500 x 127mm) Telescope
Light on telescope on powerup but nothing from autostar.
I have replaced controllers and cables. I took bottom of telescope off and found wires disconnected. I hooked those back up put it back together but to no avail. I purchased a new power cord, I checked the cable contacts. I was wondering if there was an internal fuse?
    Genius:
  • 1,027 Answers
If Meade does not offer help, there is a 3rd party that does 'supercharging' of ETX models:
http://www.weasner.com/etx/techtips/tuneup_service.html
Posted on May 04, 2010
I have a Meade ETX-70AT scope that I inherited from a neighbor years ago. It came with two eye pieces (9 and 25 mm), a tripod, and an Autostar which I believe is the #494 model. On the bottom of the...
The hand controller cable is probably defective-- right at the connector that plugs into the scope. Any computer network "wizard" can replace the connector. The wires must be in the exact same sequence when he repairs it.
If this simple fix does not work and you KNOW that the batteries are good-- then the hand controller is defective and will need to be replaced.
Jul 04, 2011 | Meade 494 AutoStar Telescope Control Unit...
I am using an LX 200 GPS gimbal with no autostar control hand box. I want to be able to talk to it using my Autostar Suite and a computer. I have the USB to RS 232 cable and the connector to go from the...
1. Plug the cable into the BOTTOM of the hand controller-- NOT into the control panel.
2. Set the software to the proper COM port. Look under Telescope in the dropdown tab.
Feb 18, 2011 | Meade LX200GPS Telescope
My telescope/autostar not working ,will only display startup info on handbox ,then nothing happens !.
This is sometimes caused by a bad hand controller cable and or corrupted firmware in the hand controller.
Get a new cable first and try it-- if this does does work then RESET the hand controller and reload the firmware using the proper computer cable and Autostar Updater Version 5.9 available here:
http://www.meade.com/support/auto.html
http://www.meade.com/support/Win7_ASU592_Installation.pdf
Aug 31, 2010 | Meade LX200GPS Telescope
Autostar wont turn on
Unless Sam's has a batch of all bad telescopes???? Check that you put the batteries in correctly. You may have one or all reversed?
and or try a separate 12 volt power source if they included a cable. If not return the scope again!
Nov 15, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
Display on the autostar does not light up. The batteries are all changed, the power light comes on on the tripod, but the handset is dead.
Could be a cable problem. REVERSE the cable ends and try it again. Make sure the scope is always turned OFF before you plug or unplug a cable.
If this does not work then try a new cable. Meade sells these, or you can order a nice one from www.scopestuff.com . Not very expensive.
If after installing a NEW cable it still does not light up then time to buy another hand controller.
http://www.meade.com/support/index.html
http://scopestuff.com/
Oct 31, 2009 | Meade 494 AutoStar Telescope Control Unit...
ETX-125 Autostar controller not working
I assume the small red light on the power panel is ON. ???
If it is the scope is receiving power--- check to make sure the cable from the hand controller is plugged in properly-- jiggle the cable to see if you have a loose BAD cable. Before you panic --- try another cable or reverse the ends ---
Before you buy another hand controller try a new cable-- scopestuff.com sells a nice long flexible one for the 497 hand controller.
Jan 14, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Autostar
Double check the cable from the Autostar to the telescope. Sometimes the ends go bad. They can be replaced with regular telephone cables.
Aug 29, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Computer control and pointing with NorthStar Goto & Autostar
Your reseller is correct. The wire (Meade cable #505) goes from an RS232 serial port on PC to a 4pin RJ plug. This plugs into the 2nd socket on the bottom of an Autostar 497 handset, the other socket being used for the curly lead to the telescope. So it goes PC to Autostar to telescope.
A common error is to try plugging the serial wire into an "AUX" ort on the telescope control panel - same connector. Not only does this not work, it can cause a lot of damage.
Wired like this you can control the scope from Meade's Autostar Suite (or many other planetarium softwares). You can also update the Autostar software to the latest 2009 version.
What else can go wrong? Well, many people want to control from a laptop, and modern ones don't have RS232 serial ports. Then you need a USB-to-serial convertor dongle, which effectively add a serial port to a laptop. But they often give it a very high port number (eg COM17) that the planetarium software does not find. Use Control Panel to reset the USB-serial-port to COM 1, 2, 3 or 4 and all should be well. But it can be a right fiddle!
Apr 01, 2008 | Bushnell NorthStar Goto 100mm 788840...
MEADE LX90 TELESCOPE
I ended up replacing the Hand Controller with a new one.
After that it started working. I brought the new one on E-bay.
They seem to have the best prices. Forget about talking to Meade. Their innate ability to reply to your phone calls or emails just doesn't work. I will ***** buy a telescope from them again.
Aug 31, 2007 | Meade 8" LX90 LNT Schmidt Cassegrain...
Meade ETX-125EC (500 x 127mm) Telescope Logo
108 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
