Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
My grasshog weed trimmer only spins when it is upside down.
The head only spins when I turn it upside down.
    President:
  • 1,902 Answers
It sounds like the rod that runs from the motor to the head, is either loose or it has broken, so when you turn it upside down that causes it to engage itself and turn. You will have to take this apart and make sure that the holding clamps are in place
Posted on May 04, 2010
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Weed eater wt255cls brand new starts but the trimming head is not spinning? seems to be in neutral?
hello,,There are only three things to cause trimmer head not to turn.
1.Outer shaft has sliped down from engine because screw has fallen out and ring has come loose,
2.Shaft has broken due to excess stress,such as putting on a differant trimmer head or binding up,
3.Trimmer head striped.
hope this helps,any comments welcome,thank you.
Jan 08, 2012 | Garden
Head on weed whacker wont spin
If the weed **** head turns freely before starting and after started still doesn't spin, check for a broken flex shaft or damaged end.
Jun 18, 2011 | Garden
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
How do you put string in
turn trimmer upside down grab the spool head firmly and pull out replace string but wind in the way arrow shows you and replace fishing the loose end back through the hole on the side as you slip back together ,once together grab string and pull to remove any slack and away you go
Aug 22, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
B&D grasshog XP motor squeeled and spin rate slowed. repairable?
I just saw your post. Check the area between the housing and the head, along the shaft. Fibrous debris (in my area, this loosely translates into "lilly leaves") gets wound around the shaft, and will slow the universe down to a crawl. The only way to get it loose is to cut it loose, or unwind it.
Best regards, --W/D--
Aug 18, 2009 | Black & Decker 14" Grass Hog Xp...
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
366 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
