Question about Denon AVR888
Denon avr-888 problem with the receiver shutting off
Whenever i go to put the surround system on the tuner for FM radio, it cuts the power off when i turn it up, meaning the entire receiver powers down once the volume is up a decent level. anyone have an idea about why this is? the surround works on everything else just fine with ipod and the TV surround, on the tuner it works great with the 3speakers but when all 5 are on it cuts off like that
Toufic Malek
  • 9 Answers
SOURCE: denon avr-1700
If you have the owner manual check for reset and reset the unit. If you don?t have the manual unplug the power cable for a wile and then try again. Good Luck Toufic Malek
Posted on Sep 25, 2007
tech48
  • 624 Answers
SOURCE: Denon AVR-1907 blinking red power button
It sounds like you have a bad speaker on the zone 2, or you have the speakers connected improperly.
When you engage the zone 2 a relay clicks and the speakers then become part of the amplifiers circuit.
If the problem was in the amplifier, it would go into protect mode without even having speakers connected to it.
If the speakers all check good, you most likely have the wrong type of speakers, meaning the impeadance is too low, or you have too many speakers connected to it.
On the back of the Denon, you will see right around the speaker output jacks, what ratings the speakers should be. If I remember correctly, it says 6 ohms or more when using only "A" or "B", and it says 12ohms or more for "A" + "B".
If you have two 8 ohm speakers on the same speaker jack you now have a 4 ohm load. That is below the ratings and can cause the amp to shut down (go into protect). Since your amp shuts down right away, I think you have a bad speaker or way too many speakers connected.
I have seen many times when people will connect 2 or 4 speakers to the one of the outputs that are designed for only 1 speakers.
If you are using too many speakers you will need a speaker distribution box. It has a resistor network built into it so the amp never sees a lower impeadance than what it is designed for.
You can connect 4, 6 or 8 speakers to one set of outputs designed for 2 speakers. You do loose a lot of power to the speakers, but it is better than blowing up your amplifier.
If I can be of any further help, let me know.
Posted on Jun 22, 2008
SOURCE: Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
Is the sub woolfer out powered? My sub woolfer is not
Posted on Jun 25, 2008
  • 119 Answers
SOURCE: Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Posted on Feb 25, 2009
Gurudristi
  • 98 Answers
SOURCE: Technical Problem on my Denon AVR 2802
How good are you with electronic repairs...? Do it if only you are confident...
The way you describe you problem it seems more like poor solder connections somewhere on the board. Usually these are at the voltage regulators where there can be some heat. Also, look for any connections that appear to be grasiny or have rings and resolder them too.
Alternatively, suggest that you take it to the Denon service center closest to you.
Best of Luck..
Posted on Mar 05, 2009
Have Denon AVR-2313ci receiver. FM tuner quit working; will tune in 50 MHz steps, on every step "stereo" and "tuned" are lit but no sound comes out whether actual station or not.
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
Oct 25, 2016 | Denon AVR2313 7.2 Channel A/V Receiver
I can't seem to get the tuner to work on my Denon AVR 2803 receiver.
It can't hurt.
You will lose all your settings though. So you'll have to set the amp up again from scratch.
Before you do initialise, let's just check.... You plugged in a FM or AM aerial, right?
Sep 13, 2014 | Denon AVR-2803 Receiver
Somehow my denon 2308ci's setting got changed. I have cd/dvd play attached, a comcast hd cable box inputted to the receiver then back out to a samsung 1080 lcd tv, and of course an am/fm tuner in the...
It seems you are not unfamiliar with censorable abbreviations.
RTFM and go through all the settings again.
http://www.retrevo.com/support/Denon-AVR-2308-Receivers-manual/id/3837dj882/t/2/
Your unspecified external devices all have settings, cables and (if digital) the ports on the Denon may need to be assigned.
Sep 25, 2011 | Denon AVR-2307 Receiver
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
Jan 29, 2009 | Denon AVR-1802 Receiver
Problem to find radio station on tuner?
FM ( at least in the USA) only goes 90.1-90.3-90.5 and so on.
This is how stations are separated.
There are no stations on 90.4 or 101.6 and so on
Nov 02, 2008 | Denon AVR-1803 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Denon AVR888 Logo
100 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
