Question about Intel Easy PC Camera Webcam
Pc shuts down after I turn on cam and I don't know why. how can I fix it?
    Guru:
  • 109 Answers
Check the Event Viewer if there is any Error Log related with this problem. Check the USB port and also you probably might need to re-install the Webcam again.
Posted on May 04, 2010
If the cam shaft sender goes out will it shut the car down even if no sputtering or no warning and it's running,just cut off like you turned the key off
it will just shut off the engine because the ECM will have no idea of the position of the cam in relation to the piston
The ECM needs to know the exact position of the crank and cam shafts to determine the ignition timing so if one or both go out then the engine stops
If course if the timing belt breaks the same result happens as the cam shaft sensor stops sending a signal to the ECM so the ECM shuts the engine down
Feb 24, 2016 | Cars & Trucks
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
I have a gateway m series laptop. the cpu fan was making a bunch of noise. I don't know much bout fixing laptops but i opened the panel n took the fan out completely blew out the dust and put...
if your pc shuts down in 10 second with black sreen it means that your laptop memory was not detected. solution: reinsert your laptop memory (RAM) .. be sure to clean it especially at the contact points.
Jul 05, 2011 | Gateway Computers & Internet
Whenever i connect my cam to my lappy it gets shut down,it was never happened before wen i was using my cam,but now it shows some message like " some serious problem occured with ur hardware usb...
As your message suggested, you have a hardware fault which means your camera is possibly faulty.
I would book it into a repair shop and get it fixed.
Hope that helps.
Jan 23, 2011 | HP Compaq 6720s Laptop
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
This web cam shuts down all internet programs when I turn it on
Please reinstall the drivers for the webcam to your system
Jul 10, 2009 | Sony VAIO VGN-CR220E/P Notebook
My Acer Aspire 5630 shuts down by itself after about 10 minutes when I am on skype
I think the first thing you should check in the power save, Down by the clock, i know you can change how long your laptop is on to save power plugged in or on battery
Nov 30, 2008 | Acer Aspire 5610-4648 Notebook
Acer crystal eye webcam
my webcam is up and running and i do not know what i did to fix it. but thank you for your help.
Apr 03, 2008 | Acer TravelMate 2300 Notebook
Cam keeps shutting down
This sounds to me like a driver issue? anyway get another copy of the LATEST driver for VISTA from Logitech, uninstall OLD driver and re-install new... this may fix ya problem.. else suspect the camera, and try another?
Feb 07, 2008 | Logitech QuickCam Express Web Camera
Intel Easy PC Camera Webcam Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
