Question about Brother IntelliFax-2820 Laser Fax
Toner life i recived a message that toner life ended bought new toner then it gave me amessage that dust was on the drun took out the drum removed the dust now it says toner life ended again I replaced the toner cartridge, cleaned off all the parts I could reach, used compressed air and it still gives me the message "dust on drum".
  • 813 Answers
Ok take the your cardinge to printer repaire
he will guide u what to do
Posted on Mar 26, 2008
    Master:
  • 788 Answers
This machine most likely uses optical sensors to detect toner level and drum quality. Use a soft cloth and wipe inside the printer all the surfaces you can reach, especially any clear plastic or glass windows that may be covering a sensor. I will try to research your problem further.
  • Brother Master
  • 13,433 Answers
Reset the printer by takeing the power plug off for 5 minutes.
  • 1 more comment
  • Ekse Mar 26, 2008
    if that doesnt do it il look for reset instructions in one minute.
  • Ekse Mar 26, 2008
    Download the manual from here If you dont already have it
    http://www.brother-usa.com/manuals/defau...
    the users manual
    Page 105 Or 11-17
    follow the instructions to clean your drum again.
  • Ekse Mar 26, 2008
    try this
    1. Open the front cover.
    2. Press the Options key on the control panel.
      The display will show "REPLACE DRUM - 1.YES 2.NO".
    3. Press 1 to reset the drum count.
    4. Close the front cover.
  • Brother Master
  • 19,396 Answers
You need to reset your Brother printer to get rid of the message
  • Ginko
    Ginko Mar 26, 2008
    when you put the new drum/toner unit in, you leave the front door open,
    press Options and select "yes" when the "replace drum?" message comes
    up. That's all you have to do.
2 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: toner life
http://www.fixya.com/support/t243667-mfc_7220_replaced_starter_cartridge_new
Posted on Nov 11, 2007
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
I have the MCF 7340. I am getting a message - End of Drum Soon. So, I bought a new drum ($120) and installed it. Now it says Drum end. and won't print. Ive turned the machine on and off several times,...
If you open the front cover of your printer where you install the toner cartridge and press the "Clear/Back" button with it open, an option comes up on your LCD Display that says "Replace Drum?" press 1 to reset it. That should fix your problem!
Sep 11, 2010 | Brother MFC-7340 All-In-One Laser Printer
Drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Apr 19, 2010 | Brother MFC-8860DN Printer
Drum error. dont have user guide. how do i troubleshoot? tried replacing drum but still says drum error.
If the drum is used up you open the front door and press menu or options and tell it it's a new drum, otherwise you clean the metal contacts on the sides of the drum and inside the printer, and run the blue tab back and forth about 20 times. If still drum error you may have a bad power supply.
Jan 30, 2010 | Brother MFC 7840W Printer
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
Toner end life message
i solved the brother mfc8860 toner life end problem
hi guys my name is reedwaan. Im new at this site so please listen up
my brother toner i refilled with toner and inserted it. It said toner life end then i patched the windows close on the sides and still the same problem, then i removed the toner and loosened the two screws on the left by the gears then removed the cover of the gears.
Right at the back there is a funny looking gear with a spring behind it. All you have to do is pull the spring a little bit clockwise and push the gear back on hooking the spring into it so that the gear is spring loaded. close it up then test it, It took me a while to figure it out but i got it right.
NB*  The gear that you push on, is the toner reset gear and when you push it on make sure the teeth dont interlock with the second gear on the left of it. If you have any queries mail me on reedwaan@yahoo.com
glad to help out
Jul 07, 2008 | Brother MFC-8860DN Printer
Toner life
where and how to find the reset actuator?
Nov 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
302 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
