Question about Sanyo Split System Air Conditioner
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
A system of 3 units of SANYO air conditioning units - one of the units always leaks water when it is starting after a long period of non usage. Then when used during a few months period, this unit leaks water sporadically - none of the other units do that. What can be the problem and how can it be fixed it in order to prevent the leakage ? tk u
  • 674 Answers
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
Posted on May 04, 2010
    Sergeant:
  • 107 Answers
I have only ever had my AC leak once and so I decided to have it checked. You may want to call up an air conditioning repair service to repair it for you. A leak can lead to mold and possible other damage so it is best to get it fixed as soon as possible. Air Conditioning in Chetek WI Stellar Heating Solutions
Posted on Aug 27, 2015
  • 4 Answers
I just had a repair man open my Sanyo ductless AC (split unit), and pour water over the top of the unit. I thought this would make a bigger mess, but to my surprise, the water drained through the unit. He poured two bottles of water on it, put the unit back together, and the leak was gone!! Apparently dirt/dust on the cooling coils can cause condensation to flow around the drain pan, through the unit and on to the floor.
Posted on Jul 05, 2015
How do i do when the indoor unit start water leaking non stop??
Water leaking depends on 18 reasons. Plz let me be cleared that voltage, amphs, gas pressurer, indoor motor condition, cleanliness of the indoor evaporator coil., etc.
Sep 20, 2014 | Heating & Cooling
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
I have a sanyo split system and one of the inside units creates ice around the coils. the filters are clean and there's nothing blocking the air around it. What can it be?
There are reasons for.
1. Dusty indoor coil and blower wheel - Clean it.
2. Less speed of blower motor- Replace capacitor/motor
3. Short of gas- Find leak and rectify.
Thanks.
Jun 29, 2011 | Sanyo Split System Air Conditioner
How to remove heater core on a 1994 isuzu pickup
Removal & Installation
Fig. 1: When installing the new heater core take great care not to bend or damage the fins or tubing
[IMG]http://i665.photobucket.com/albums/vv17/technovative/Isuzu-Pickup-Heater-Core.gif[/IMG]
Click here if image doesn't display.
  1. Disconnect the negative battery cable.
  2. Drain the engine coolant into a suitable container. CAUTION
    When draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  3. Disconnect the heater hoses. Be careful not to damage the core by pulling on the hose to remove. Cut the hoses if they will not come off easily.
  4. Remove the instrument panel.
  5. Disconnect the resistor assembly.
  6. If possible, disconnect and move the duct (non air conditioning) or the evaporator housing (air conditioning) to the right to gain clearance for the heater unit. If equipped with air conditioning, do not disconnect air conditioning system until absolutely necessary. Refer to Section 1 for discharging, evacuating and recharging the system.
  7. Remove the instrument panel stay and heater unit.
  8. Disassemble the heater unit by removing the duct, mode control case, core assembly and heater core. To install:
  9. Assemble the heater unit by installing the duct, mode control case, core assembly and heater core.
  10. Install the heater unit and instrument panel stay.
  11. Connect the duct (non air conditioning) or the evaporator housing (air conditioning) to the heater unit. Evacuate and recharge the air conditioning system if the system was discharged to remove the evaporator assembly.
  12. Connect the resistor assembly.
  13. Install the instrument panel as outlined in this section.
  14. Connect the heater hoses. Be careful not to damage the core by pulling on the hose.
  15. Refill the engine coolant into a suitable container.
  16. Connect the negative battery cable and check for leaks.
Jan 30, 2011 | 1994 Isuzu Pickup
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
The insiside unit is cover with ice and leaking water
The unit has a leak and is low on charge...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Nov 26, 2010 | LG Art Cool LA181CNW Split System Air...
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
Water is leaking inside the house
The drain that should be carrying the condensate water outside is stopped up. Compressed air works well to clear the drain.
Jun 22, 2010 | Sanyo 18KS52 Air Conditioner
Sanyo  Split System Air Conditioner Logo
814 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
