Question about Sewing Machines
Freesia Sewing Machine
I am not sure what the part is called. It is the piece that attaches to the machine and holds the needle in it? I am sorry but I do not know the terminology for that piece. Hopefully you can help me.
  • 106 Answers
The long metal bar that comes vertical from the machine that the needle fits into is the "needle bar". The piece at the bottom of the needle bar that secures the needle is the "needle clamp"
Rob
Posted on Mar 28, 2008
I took my needles out to change them and can't get them back in!
Heather, switch off machine from electric supply.gently lay machine on its back, you will then be able to look at the needle holder .remember the needle has a flat side and this must corispond to the shape where the needle enters into the space for it . be sure you tighten needle into place with the tool provided for the job. Reston machine back onto it's base . Tread up machine and slowly turn by hand the side wheel to make sure the needle is in the right place. When this is working you can refit electric cable as continue sewing. P'S try sewing on a bit of spare fabric to make sure all is well..happy sewing , lois
Aug 20, 2016 | Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
I was sewing with my Singer Confidence 7470 when it suddenly would not pick up the bobbin thread. I changed the needle, re-threaded the machine, and checked that the bobbin case is clean and in correctly...
Yes, try looking very closely at the needle assembly. Make sure the new needle is loaded with the flat side against the arm that holds it. If the machine is only a few months old, it's probably under warrantee. There should be a number to call on the serial plate. If all else, call the store you purchased it from. Sometimes they have sales people who are well versed with their equipment and can help you but I bet the needle is facing the wrong direction when you replaced it. Find any broken pieces of needle and remove them too. Look with a flashlight. I hope this helps!
Sep 22, 2011 | SINGER 7470 Sewing Machine
How do I get the outside case off the husqvarna sewing machine freesia 425 to get to the inside mechanisms?
I don't know about a Freesia specifically, but I saw my tech. literally rip off the front of my Designer 1 once - took me years to get over the trauma!! I think with most of these modern plastic machines, the various parts of the cover are clipped on. You just need to be brave, take a hold, and go for it. I would be sure to remove any "loose" bits and take a good hard look at which bit fits where first. Try jiggling the part you want to remove to see if there is more "give" in one direction than another. Also be prepared in case you accidentally break the lugs that hold the piece in place.
Oct 10, 2009 | Husqvarna Freesia 425
Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
The needle keeps breaking.
make sure the needle is set to the correct position
Jan 27, 2009 | Husqvarna Freesia 415
The piece that holds the needle has come off the machine
Generally, there will be a cut out inside the 'needle clamp' that will allow it to only go on the 'needle arm' one way 'round as it slides over the shaft.
The screw to tighten generally comes in from Right to Left.
If this does not help entirely, try taking a look at any other machine, mum's, friend's, in a store....etc and take note of the arrangement.
If you have a friendly local sewing shop where you buy threads etc, ask if they could show you.......plead accident, unattended young fingers, whatever......the easiest is to compare a good one ans see how it should be.
Hope this is of some little use.
May 21, 2008 | Brother XL-5130 Mechanical Sewing Machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
