Question about Mitsubishi WD-65735 Television
I just change the lamp on this DLP TV worked fine for a day and now it does not come on there is sound but no image
  • 111 Answers
Not seeing the set it is hard to say, but a lot of times the pins in the adapters to the lamp become loose or do not sit properly. It sounds like it might not have been the lamp, but a power supply problem.
Posted on May 04, 2010
Testimonial: "Thank you good answer"
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Making beep sound lamp
Hello, I think I understand the question, your TV is making a beeping sound indicating its time to change the lamp? If so I suggest you go with the original Philips on the link below, to get the brightest image possible.
Feb 03, 2014 | Samsung SP50L6HX 50" DLP HDTV
Thomson tv projector 61DSZ644 schematic diagram power supply board
Thompson 61DSZ644...Hello,I have a big problem with this tv.When i start it,the sound is good,but the image is very ,very dark.I buy a new lamp,i change it,but i must change the two wires from the lamp because the new lamp have it change.It came from china and is the same lamp,with the same specifications,just the polarity wires is different.so i change it and when i start the tv,i can see the image better but not normaly,the image is like in the white fog,even if the lamp is new...and after 20 seconds,the ventilator from lamp is stop and TV enter in stand by.Can anyone help me about this problem?
Mar 21, 2013 | Thomson 61DSZ644 Rear Projection Lamp...
Hitachi 53FDX01BA with no picture, sound is fine.
Sounds like it could be a problem with the DLP Lamp. There aren't any noises coming from the TV to suggest heat failure or the colorwheel going out is there?
You've got sound but no image, I'd say it's the lamp.
I get my lamps from DLP Lamps.com, they come with instructions for self installation, and even come with gloves!
Dec 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hello. I have a Zenith DLP Projection TV that I bought new from the store (possibly the display in the store) that has been working fine for 2 years. Just only a few weeks ago, the color seemed a...
Sounds like you need to replace your lamp and the tv will work fine until the new lamp goes out. I have had three lamps since Nov 2006 in mine and I have a notice coming up on my Panasonic saying I need to change the lamp right now. Which is strange, because before there was no warning, it worked fine and then when we went to turn it on again, it just did not work until the lamp was replaced.
Oct 05, 2008 | Televison & Video
52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
May 13, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65735 Television Logo
381 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
