Question about Exercise & Fitness
Carl Lewis MOTC66 E03 error HELP !
Hi all,
I have a Carl Lewis MOTC66 treadmill. After some time the control board gave up .. probably overheated after 45 minutes in use. I ordered a new one but its gives error code E03 at the speed. When you turn on the treadmill it counts down for 5 seconds, then for one second it turns the motor but then stops (relay click).
I've cheked the cables and the opto sensor for speed at the motor but they are fine. Anybody have an idea? Please mail me via: pa3fxo (at) hotmail.com many thanks in advance! Regards, Cees
  • pa3fxo May 06, 2010
    Thanks for the reply. It is a MOTC99 Treadmill and the motor is allright ... brandnew and I tested it. Also tho opto coupler which measures the speed is o.k. I returned the controlboard and will wait for them to test it as it maybe faulty regardless its new.
    President:
  • 832 Answers
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
Posted on May 06, 2010
    New Friend:
  • 4 Answers
CODE E03 SHOWN WHEN WE START AND COUNT 5 TREDMILL STOP .
Posted on Oct 03, 2013
Carl lewis mot566 treadmill error code e03
please adjust the REED switch, see the diagram attached. Clean it +test it for open or faulty+tight the connector very well.
However if the problem persist error code 3, this is a problem with the PCA memory location, RAM. the solution is to replace the PCA.
Try to RUN the software calibration for easy diagnostic, and fix it
God bless you
Jun 22, 2013 | Exercise & Fitness
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
What does error code 0E1 mean on a carl lewis motorised treadmill
Dear Sir:
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1. .
sincereley.God bless you.
ernesto cuadramanagua, nicaragua c.a.
Feb 15, 2012 | Exercise & Fitness
Carol lewis mot566 error code 03
1)probably a faulty speed sensor
2) speed sensor is not plugged in properly.
3)possibly a faulty motor
4) Main control board or lower board.
Check this video for speed sensor.
http://www.youtube.com/watch?v=23ZgWaVEQjA
adjust the speed sensor:Move the motor to slacken the pulley, then lift the motor to get underneath. That is where the treadmills speed sensor will be located. It is usually a square or rectangular shaped green module with connectors at both ends.
Finally after you did the adjustment you can conclude:
A) Faulty Speed sensor B) Main Motor faulty C) Main Motor Controller faulty.
attached block diagram for treadmill that I did for any treadmills,see how the Main Motor Board has function for 90% of the treadmills.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 23, 2011 | Exercise & Fitness
Error E07 on Carl Lewis Treadmill
does any1 know how to fix the e07 error on the carl lewis tredmill or why is has appeared?
Feb 06, 2011 | Sport & Outdoor - Others
I need an instuctions on how to start a carl lewis treadmill
http://cgi.ebay.com/Carl-Lewis-Treadmill-MOT566-and-MOTC99-Instructions_W0QQitemZ130354874033QQcmdZViewItemQQptZUK_SportsLeisure_ExerciseFitness_Treadmil
or maybe one of the newer manuals at carl lewis might be similar.
http://www.carllewisfitness.co.uk/html/English/IB_UK.htm
Jan 17, 2010 | Exercise & Fitness
Carl lewis treadmill
I also have this problem. I rang Carl Lewis Support and they said to check the connections on the circuit board (Located in the floor panel next to the motor). If the treadmill had recently been moved something may have been dislodged. I checked mine and found a few loose wires and plugged them fully back in but this didn't help my treadmill. I'm awaiting a response from an e-mail i sent them now.
Jul 06, 2009 | Exercise & Fitness
I need a manual for a carl lewis treadmill
You can download the Carl Lewis Treadmill manual here
Apr 20, 2009 | Landice L7 LTD Executive Trainer Treadmill
Exercise & Fitness Logo
1,142 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
