So it began as one vertical line on my 52 inch Samsung that goes away after about 10 minutes. Now there are 3. But again, they go away after about 20 minutes. TV is a little over 2 years and not under warranty. Any ideas???
  • joshuafsmith May 04, 2010
    Stays in one place. The same place. Started as one and now there are 3. But again, they hang out for about 15 minutes then disappear. HELP!
  • The TechGuys May 11, 2010
    is the line moving or is it staying in one place?
  • 178 Answers
If it is a plasma TV, may be the bad connections, you can try to reconnect the cables on the Y-buffer board.
If it is a LCD TV, the panel may need to replace.
Posted on May 05, 2010
  • Shukai Fung
    Shukai Fung May 06, 2010
    Correction: I’m sorry I thought is Horizontal Line, that may cause by the cable connections on the Y-buffer board. If Vertical Line, it may be the connector loose on the buffer E or F board, some model of Samsung panels the buffer E or F board connect to the panel directly without connector, so solve the problem need to replace the panel.
  • Shukai Fung
    Shukai Fung May 12, 2010
    I’m sorry I thought is Horizontal Line, that may cause by the cable connections on the Y-buffer board. If Vertical Line, it may be the connector loose on the buffer E or F board, some model of panels the buffer E or F board connect to the panel directly without connector, so solve the problem need to replace the panel.
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
When I first turn on the TV there are 3 transparent lines that appear.
The data buffer IC inside of the display panel is bad. It needs a new panel.
Apr 20, 2017 | Samsung LNT4066F 40 in. LCD Television
TV picture goes off after 20 minutes
there are bad solder connections on the pictury tube drive module. have it fixed at a repair shop.. the tech will be mystified that you know what the problem was..lol..
Nov 12, 2009 | Televison & Video
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
Green vertical line is coming in the middle of the
monitor is probably going bad. Try hooking up a different monitor up to the computer, one that you know works properly. If the same problem exists then its the video card, if the problem goes away then its the original monitor that is bad.
Aug 16, 2009 | Samsung Computers & Internet
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
