Question about Dell Inspiron 9200 Notebook
My volume meter disappeared. I went to control
My volume meter disappeared. I went to control panel on sound settings and unchecked, then rechecked the display volume icon, and now I have a different volume icon that only shows mute or on. The volume meter does not display.
    Guru:
  • 109 Answers
Follow this path:
Start >> All Programs >> Accessories >> Entertainment >> Volume Control
See if you get the Volume control or not. If you are able to get the Sound properly then you can create a Shortcut of Volume Control from the same path whihc i given...
Posted on May 04, 2010
When missing the volume meter indicator. this is what I done. Clicked start, search, then clicked all files and folders. Typed in quickset, then opened the document that was found which was quickset. when the quickset box opened, I clicked on power management settings and followed the steps. and the volume indicator was back up.
Posted on Feb 01, 2013
The sound icon on my HP laptop disappeared
If the sound is muted go into the Volume control and uncheck the Mute box.
If this does not work then reinstall the audio driver.
You can download the audio and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 17, 2013 | HP Computers & Internet
My volume icon on the task bar has disappeared, how do I get it back
Open the TASK MANAGER, open the PROCESSES tab, highlight "explorer.exe", click on "end process", Open "file", "New Task", Type "explorer" without quotation marks. OR Control Panel, Sound, depending on your OS, You will find a box to show tray icon. If it is checked, uncheck, apply, then check, apply. The Task Manager will remove stored icons that fill the program, and restart the icons.
Nov 28, 2012 | Dell Inspiron 1501 Laptop
I have checked and rechecked the setup and I am getting no sound. I have sound signals from my soundcard but no sound coming from my speakers. They are on. The power cord is plugged into a fonctionnal...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hope this helps you
Sep 19, 2011 | Logitech Z-2300 Computer Speakers
Satellite a135-s4527
go to control panel,, then sound..
look to see if you have working device under sound playback..
if you do look for [place volume icon in taskbar] under volume tab [1st tab]
It will have a check box,, if the box is not checked then add the check mark by clicking on it,, then apply..
If the [Place volume icon in taskbar] is already checked then un check it.....apply...then re-check it....apply.
I dont know y but there is a glich and sometime yo have to uncheck and recheck to get the icon back...
I hope this helps you.. it should if your sound works at the moment
Mar 12, 2010 | Toshiba Satellite A135-S4527 Notebook
Does anyone know how to add the pc beep slider back to the master volume properties? it's disappeared as an option.
1.Go to control panel>sound and audio devices>on the tab of device volume , click advanced. You will see sliders (master volume window), go to options>properties>tick the "PC Beep" to make it appears in volume control. Now just unmute it
2.If this doesnot work,try this
Control Panel. Click Start > Settings > Control Panel > Sounds and Audio Properties, then the Sounds tab.
Changing the Sound scheme to Windows Default should get it back to normal. If it’s already on Windows Default, you can try setting it to No Sounds, click Apply, then set it back to Windows Default and Apply again.
If that fails, I think you’d have to reinstall the sound drivers.
Aug 17, 2009 | Computers & Internet
On the lower right corner of my screen usually next to my battery meter and clock used to be my volume control. but now its gone and i dont know how to get it back, can anyone help?
Go to start, up to control panel. Look for sound and multimedia icon or sound and audio devices icon ( depends of windows version) Click on it. A new box will open on your screen, on the volume tab is a check box for "Place volume control on taskbar" be sure it is checked. Exit the screen and your volume control should be back.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
Jun 19, 2009 | Compaq Armada E500 Notebook
I was muting the sound from the mic on my notebook and now I cannot get any sound from the speakers. Could you please help.
hello,
did you see the volume control in the task bar? you can double click that and then set the not to mute or uncheck the mute option. of the volume, mic and other setting.
you can acces this also the control panel in the sounds and audio controller. "Double click the sounds and audio devices then set the or uncheck the mute option.
may this help you.
melnavz
Oct 20, 2008 | Acer Computers & Internet
Hp zv5346us audio problem
Try to look for the sound icon in your task bar. select properties then try to check options then select all settings that are supposedly running in your system uncheck those settings that are set to mute then adjust the volume lever to higher level.ex. Right Click sound icon,-open volume control, When volume controls appear click on the properties,-then select all settings that you might be using then close the volume control panel. then try to run again. if possible it needs restart to take effect the new settings.
Oct 08, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I need your help now there is no volume on my computer
Try looking at Start>Control Panel (Win XP) and the double-click on Sounds. Check the settings to see if they have been muted. If it is checked then uncheck the box and you should have sound. If unchecked then the volume may simply be all the way down. If neither of those then you may have a device problem. To check in XP goto Start>Control Panel. Double-click on System and then click on the Hardware tab. Click Device Manager and see if you have a question mark by Sound Category. If you do try removing by right-clicking and choose remove. Reboot your computer after this to see if your computer will reinstall the sound card.
Jul 25, 2008 | Computers & Internet
Volume problem
http://pettersservice.com/polaroid/docs/FLM-Series-26-32-37-ServiceManualFinalNA_20070418.pdf
it says to replace the control box for no sound.
thats the main board to you.
I would use external speakers as they sound better anyway.
Jan 24, 2008 | Polaroid FLM-323B Television
Dell Inspiron 9200 Notebook Logo
857 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
