Question about PC Chips M871G Motherboard
Hello i replace my small ups 650VA battary with a car battary,when i charge the car battary with an external charger does this affect my ups if it remain connected with the battary
    Genius:
  • 1,027 Answers
Should not be a problem - just make sure the charger is a good one, and avoid over-charging. Once the battery is fully charged, the UPS should maintain it properly. Also, check the water level once a month - dry cells will kill the battery.
Posted on May 04, 2010
Testimonial: "good "
Pro 650va
hi i am rehan frm karachi 03312504748 ap k ups ki battari kharab he
Jul 24, 2013 | APC Back-UPS CS 350VA - UPS - 350 VA - UPS...
My samsung strive is not charging, what could be the problem? I put a new battary but is not charging
when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care, and wish you good luck in solving the problem...
Jun 10, 2011 | Cell Phones
Hello sir, I don't actually know how to charge my apc cs 650... and And when the power is out, so does my computer.. low battery.. I just need a simple answer about this.. is it not charging? or do i need...
If you connect the control cable to a PC and install the PowerChute Personal Edition V3.0.2 f software you should be able to see if it is charging and what the percentage of charge held in the battery is.
On the CS 650 the lowest power connection is the surge only powerpoint.
To give the battery a full charge or to test it you can connect it to a car battery trickle charger, as it is a 12 volt battery, rthis will at least mean you can check that it holds a charge in the first place.
Dec 23, 2010 | APC APS BackUPS CS 650VA 400W 230V DB9...
I have Toshiba satellite M35X-S163 when press power cpu fan start and hdd run for 2-3 seconds then gose off nothing on the screen internal or external ; in addition no battary charging . battary and the...
in the pic that is not m35x that is m30 ... if u have m35x ...and no display open the laptop near the power jack there is maxiam ic ... jsut heat that ic.. hope that will work .. if not let me know thanks
Oct 08, 2010 | Toshiba Satellite M35X-S163 Notebook
My Nikon D70s is not staying charged. I turn the camera on
the camera is provided with a battary charger,take out the battary from the camera put it in the given charger,charge it till u get green light,then try.
Apr 05, 2010 | Nikon D70s Digital Camera
My nokia 5310, won't charge. I plug it into the wall, then it just stays there and nothing comes up with 'charging' like it used to before. I left it on charge overnight, but when I took it off charge the...
My Nokia 5310 also wouldn't charge; pocket lint had become trapped in the charging hole, and was packed down over time. I used a very thin straight-pin to gently scrape the lint out of the hole until I could see the gold-colored metal pad at the bottom (using a very bright flashlight and small dental mirror to direct the light). That took about 20 minutes. Now the charger plug slides all the way into the port and clicks into place. Tip: Be gentle, that center pin will break if you try to use something fat, like a safety-pin or a toothpick. -- John Dollison, Colorado.
Oct 29, 2009 | Nokia 5310 Cellular Phone
I have canon zr800 camcorder,its battary not gatting charged.
can you try to used a new battery if it works i think your old battery have a problem.
thanks,
Jun 23, 2009 | Canon Video Cameras
Battary
It Prompts when Battery Low -
But U Havent Looked at it -
U Just might have put it to Cable to charge -
But it doesnt -
So Means u have to change Charger -
Be See that ur Charging socket isnt Loosened -
Then change ur charger with a Newer n Original
One -
Jan 20, 2009 | Cell Phones
PC Chips M871G Motherboard Logo
59 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
