Question about Xerox DocuColor 12 Color Copier
Dc1q2 I have replace the drum cartridge but the prints are not dark Please advice how to make dark copies darker in the service mode
    President:
  • 2,072 Answers
What is sounds like to me, it you need to replace the developer.
Once it is in the machine for an extended period of time, the ink no longer transfers onto the drum properly and your copies become washed out.
It is rather amazing the differenece a fresh shot of developer will make.
Posted on Mar 27, 2008
Prints and copies coming out with dark spots
Please replace the cartridge /toner with a new one and see what you get.
Jan 31, 2012 | Canon iR1510-1670
Poor copy quality
The drum, developer and other parts have a certain life that they are good for. After they go beyond that cycle they can start to run dirty, use alot more toner, basically give you problems until a complete maintenance is done. The drum can have permanent light fatigue, even though they look good and in alot of cases one side will start to get darker than the other. You should get an estimate of what it'll cost to have servicing done and compare that with the cost of a new or refurbed machine. If the copier is very old, it might be worth it to get a new one. Good luck, please rate this if it helped you. Thanks
Jul 02, 2009 | Xerox Office Equipment & Supplies
Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Apr 20, 2009 | Canon PC170 Copier
Resolution is getting poorer and copies are getting darker
A new drum cartridge is in order; this is a DIY replacement and the company linked below was a reliable source over many years of such service:
Precision Roller
Jan 19, 2009 | Brother MFC 6800 All-In-One Laser Printer
Copier too dark
Did you clean the lens and the mirror under the lens cover? If so, There is a VR behind the front cover of most small Xerox machines. One VR makes the image darker/lighter and one VR changes the lead edge registration.
Dec 11, 2008 | Office Equipment & Supplies
Light Print
6b1645a.jpgThe button circled in red is the darkness/lightness button for the copier. The normal option should have a light beside it. If that light is on then maybe try setting it to darker? Hope this helps.
Oct 17, 2008 | Xerox WorkCentre PE120 All-In-One Laser...
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
PRINTING PROBLEMS
Have you tried a New Drum Cartridge?
It sounds like the drum cartridge is bad. Do you know how old the drum cartridge is or how many copies are on it?
If you take the drum cartridge out (Do not tip this upside down or touch the drum) you should be able to see a shiny long cylinder called the drum underneat the unit. Does it look like its covered with toner?
If it is covered with toner, then the cartridge needs to be replaced and that will take care of your problem with the dark copies.
If its not covered, then it could be a dirty optics which would require for your machine to be serviced. But 99 out of 100 times its the drum cartridge.
Hope this helps.
good luck.
mac
Feb 12, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Printing pages dark
The cartridge itself needs to be replaced, threre is a blade called the drum cleaning blade which scrapes toner off the Drum(blue roller) it is not cleaning the excess toner.
Oct 16, 2007 | HP LaserJet 4 plus Printer
Xerox DocuColor 12 Color Copier Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
