Canon Image Class 2210 I am a trained technician, but not on this model. When I press the print button, the scanner moves like it is adjusting for home position, it takes a few seconds, the scanner does not move, a copy comes out blank and a message appears that says "check printer".
  • 17,970 Answers
Something to try this is from a technical bulletin...
Product: imageCLASS 2200 series
Title : Intermittant Check Printer, Error Code ##0323, or Printer Status Code 8:04.
Error : Current leakage can occur where the DC controller contacts pass through the metal plate in the bottom of the Paper Feed Belt Assembly (FG6-1257-000).
Workaround : The current leakage can be resolved by replacing the Insulating Sheet which is located on the bottom of the Paper Feed Belt assembly (FB4-5644-000) or by replacing the Paper Feed Belt Assembly (FG6-1257-030).
To reset, try this....Press 'user data' or 'data registration' and then the '#' key and then 'set' or 'ok'. the display should read something like 'sssw1 00000000' scroll over to the last '0' on the right and change it to '1', press 'set' and then 'reset'. The display should now show the check printer message followed by ## XXX a 3 digit number. Report back here what that number is XXX we can help you more.
Hope help with this.
Posted on May 04, 2010
How do I adjust the setting to lighten copies?
Canon : PIXMA Manuals : Print Studio Pro : Settings Area ...
ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.3/EN/.../psp-406.html
figure: Settings area (Correction). (1) Black and White Tone Adjustment Area ... Move the slider to the right to darken and left to lighten the color. ... the XPS printer driver (Canon series XPS) for Printer in the Settings area (Print Settings).
Canon : PIXMA Manuals : MX920 series : Adjusting Intensity
ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/.../Dg-c_intensity.html
You can dilute (brighten) or intensify (darken) the colors of the overall image data ...Used Settings, and then choosing Color/Intensity Manual Adjustment under ...
Canon : PIXMA Manuals : Image Settings
ugp01.c-ij.com/ij/webmanual/ScanGear/M/MFP/19.1/.../Sg-930.html
When Image Adjustment is set, the brightness of the specified portion of the ... Use this function to reduce show-through in duplex documents or lighten the base ...
Oct 20, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
I have a Canon Image Class 8580 CDW with Error E070-0000 Changed the Fuser could it be the Transfer ?
Dear
The code due to, ITB/TOP sensor defect, DC controller PCB defect.
Do the procedure to check yourself.
1. Turn off the printer.
2. Hold down the Resume / Cancel Press the POWER - indicator turns green.
3. Release the Resume / Cancel, still holding the POWER.
4. Press the Resume / Cancel 2 times while holding POWER, then release all buttons.
5. When the indicator light remains green - press the Resume / Cancel 4 times.
6. Turn off the printer button POWER. Then turn, this should solve the problem.
If the problem not clear, take the help of trained service engineer to check the connector of the ITB unit, DC controller PCB. • Replace ITB unit • Replace DC controller PCB.
Thanks.
Jan 31, 2015 | Canon imageCLASS Office Equipment &...
Why datamax M class 4208 only prints on one side of the label?
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Apr 30, 2014 | Datamax I-4208 Thermal Label Printer
How to reset Canon mf4150
Hello and welcome to FixYa!
The manual reset Method for
Canon image CLASS MF4150 All-In-One Laser Printer is given below, Follow every step carefully:
  • Press and hold STOP/RESET button.
  • Press and hold POWER button.
  • Release STOP/RESET button without releasing power button.
  • Click STOP/RESET two times and then release power button.
Now your printer enter into service mode. Now
  1. Prepare paper on the paper tray
  2. Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  3. Press Stop/reset button for 2 times and then press power button, await till printer finished print again.
  4. Press Stop/reset button for 3 times then press power button to reset EEPROM.
  5. Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  6. Switch off the printer. if printer doesn't turn off, press button power until printer off.
You have done it
If any Further assistance required, I am here to help
I hope this solution helps you.
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) and testimonial will be esteemed.
Thank you for Using FixYa
Apr 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Canon d320 image class makes knocking sound and nothing prints
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section
pifonski
Feb 20, 2011 | Canon imageCLASS D320 Digital Copier
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
Problems installing my printer
Hi Keith,
I have helped many in your predicament, go to www.canon.com look for the support & download page log your details in with model and download the driver/s and files.
Failing this a trusty site for everything, drivers, software and downloads is www.cnet.com it has never failed me.
Good Luck! remember please to press the Blue button for my FREE Effort/guidance.
Paul 'W' U.K.
Feb 09, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Canon image class MF5750 printer/fax/scanner
If you're in the USA, go to this link. Enter your zip code or city / state and click the "Find Service Location" button.
May 22, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
I have a hp psc 2210 all in one printer/scanner etc. im getting ( press enter to align cartridges ) unable to correct, unit will not print.
Press and Hold the 'Setup' button while you press the 'Options' button. This will bypass the error and allow you to print.
You may want to tape a note on the printer with these instructions as this is a frequent problem on the one I have :)
Mar 13, 2008 | Computers & Internet
Canon image class d81
Are your copies face down in the feeder? can you make copier face down on the glass? Otherwise you have a bad scanner.
Dec 02, 2007 | Canon ImageClass D861 Printer
jasbo
jasbo
