Question about Amana Dryers
I have an Amana dryer..model ndg2335aww..the ignitor comes on and lights the gas ...the flame stays on for about 5 sec....I have replaced the coils and the thermo sensor..the thermo sensor had a small crack in the window...my problem still exists ???
  • fmertz54 May 04, 2010
    That was oing to be my next step...thank you very much
    President:
  • 2,468 Answers
Check the high-limit and or cycling switches/thermostats as if they read an over temp from being faulty they will shut the gas off,they are both on the burner tube assembly
Posted on May 04, 2010
Amana propane dryer ignitor works, gas starts then flame shuts off in 5 secs
hay bob , get your vent cleaned out ,there's not enough oxygen for the flame to stay on.good luck APPLIANCES R EN
Mar 03, 2013 | Amana Dryers
I have a model LGA30AL gas dryer. It will start up occasionally but will only stay lit for a short time. I have already replaced the Igniter. And found a small leak in gas line. I replaced that also. What...
The gas assembly consists of: The ignitor, the flame sensor, and the solenoid coils. The ignitor and flame sensor are either going to be good or bad no in between. The only thin in there that can get intermittent is them solenoids. They get hot and quit but after a long while they cool back down and work another time. themobilian_2450.jpg
Amana service Manual
Jun 14, 2011 | Amana Dryers
My gas dryer will not get warm
Can you hear the flame come on at all? If you can hear the flame come on in the beginning but then as time goes on it doesn't, you need to replace both coils (solenoids) on the gas valve.
Take the front panel off and watch the operation of the dryer. You should see the glow from the ignitor come on and get very hot, then hear the click of the coil releasing the gas, which will allow the flame to ignite. If you see the flame come on, stay there and keep an eye on the time.
After about 5 minutes if the coils click but the flame doesn't come on, you've just proved you need the coils.
If you have a meter you can check for continuity or ohm out the ignitor to see if that is your culprit. A less likely repair would be to replace the flame sensor.
Feb 19, 2011 | Kenmore Dryers
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Dryer Model DE306 has stopped heating
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 13, 2009 | Dryers
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Gas Dryer model 110-77974110
the coils on your gas valve are going out , this is why it will work at first and stop , the coils heat up and wont open the valve again after they are heated.
I thought they were some what cheaper than they are now but still not too bad. you can try this part number search on ebay for the best price I can find.
279137 coil kit
Phil
Jun 11, 2009 | Kenmore 74602 Gas Dryer
I have a AMANA gas dryer model LGA80AW and it is not heating. I took the front panel off cleaned the lint from within the cabinet and exhaust pipe. What I've noticed is that the starter comes on and lights...
When you say "starter" I assume you are talking about the "ignitor" and it is glowing.If the ignitor stays glowing continuously then the radiant heat sensor, normally closed, is not opening OR if the ignitor lights up than turns off after about 10 seconds but no flame, then the coils (doesn't matter which one of the two) are bad. The coils are located on top of the gas valve and the radiant sensor is located on the side of the burner chute....Good Luck
The Squirrel
Mar 26, 2009 | Amana Dryers
Gas dryer flame won't stay lit
Check for a blocked vent.
Mar 12, 2009 | Amana Dryers
No heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
46 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
